HOME
Discussion Forum
Cabin Property
Property Selection
Site Planning
Site Preparation
Building Permits
Build Cabin
Building Materials
Tools
Design Options
Foundation
Floor
Frame
Doors & Windows
Electrical
Interior Finishing
Cabin Cost/BoM
Other Structures
Off-Grid Living
Power Source
Water Supply
Cabin Heating
Outdoor Living
Picture Gallery
Tips
FAQ
Books
Link to Us
Contact Us
Search This Site:
Forums
Register/Sign Up
Search
Statistics
Off-Grid Living
propane question
Author
Message
morock
Posted: 6 Jan 2014 09:49pm
Quote
I bought a full size propane range out of an old farm house and want to use it this year (I bought it over a year ago). The stove is in really good shape and fairly new, less than 8 years, I will get a professional installer to do the final cabin system install, when I know what it will be. I'm looking at on demand hot water, the range and BBQ hook up. But for the up coming summer my plan is to run a flex line through the floor to a 20lb tank outside just so I can cook inside this year. From what I can determine I need a regulator and I'm good to go? I will also put in a range hood for the inspector, but will not use it much as I am on solar power. Do I need a regulator or do the newer ranges have this built in?
Posted: 6 Jan 2014 10:22pm
Quote
You will need a regulator. I used also 3/8 copper gas line from home depot, double flared (though, its not required as Mt Don and I found out unless is mobile)
The regulator, well, if the tank is outside, you could go to Home Depot and get a BBQ regulator, they are set to 11 lbs, should be the same for your oven. Its not adequate or meets code, but it works great for a temp to get it up and running.
More smilies...
Username
Password
register here
first.
Search Small Cabin Site:
