# Posted: 14 Mar 2010 22:32
Hey fellas, I have an old 50 cc honda breeze moped, wondered what you guys thought about mounting 3000w gen to the rear wheel via a belt. Fire that dude up and rev till get 3600 rpm's on the wheel ? Thought it may get exceptional gph fuel rate.. ??
# Posted: 14 Mar 2010 22:33
I forgot to mention .. .SUPER Quiet !
karlscabin
# Posted: 15 Mar 2010 02:16
About the breeze moped... I am a gear head by trade, but that dont make me the smartest grape on the bunch, BUT..... I think that yes, the motor may initially turn the generator, once a load is applied, I think you may run out of horse power to turn it effectively. This is especially true if it is a two stroke engine and not a four stroke.
larry
# Posted: 15 Mar 2010 10:30
i have to agree with karl, you have the rpm and efficiency but not the power you will need. my honda gen is 3500W and needs a 10 hp 4stroke under full load
# Posted: 15 Mar 2010 14:48
hmm OK,, how bout a 2000 w gen head? It is a 4 stroke motor,,
how many hp is 50 cc's?
It carried my body around pretty good.
knottypine
# Posted: 17 Mar 2010 22:33
50 cc is about 3 hp. you could weld it to a frame and belt it to a delco alternator to charge a 12v battery/bank. just an idea for the motor
larry
# Posted: 18 Mar 2010 21:17
now that would work! you can even get a alternator that would produce up to 140 amps @13 VDC
hbarker
# Posted: 19 Mar 2010 13:11
hmmm
hbarker
# Posted: 19 Mar 2010 13:16
just curious how long would it take a 140a altenator to charge a bank of four 6v golf cart batteries? hmm seem like they were trojan 355 AH batteries ..?....
I could run some small loads off an inverter for a LONG time on 4 of those.
knottypine
# Posted: 20 Mar 2010 11:50
getting back on topic, most 3k generators have 6-10 hp engines to power. You can use all the belts in the world, but you will never get more than 3hp out of a 3hp engine. In applications which the motor is underpowered, the motor tends to fail quickly.
Another option would be to acquire a PM DC motor of the kind folks use to homebrew wind generator, and fab that to a frame to be driven by your moped. Run that thru a charge controller to your battery bank
4 335AH 6v batteries would run small loads for a long time. As for the charging time for that bank on a car alternator, that would depend on the motor turning to alternator. An chevy 350 would do it faster than a 50cc moped motor :)
HP is just a unit of energy, just like watts. google watts to hp conversion
