Small Cabin Forum / Off-Grid Living / minimum temperature of operation for Xantrex C-60...
chris
# Posted: 19 Jul 2013 06:18pm
The manual says that the minimum temperature of operation is 32 degrees F. Xantrex "technical service" rep could only read back the manual.
Can the charge controller be used at temperatures below 32 to keep a bank of batteries charged?
Has anyone used one of these in an unattended unheated cabin in a cold winter?
GomerPile
# Posted: 19 Jul 2013 06:33pm
Think mine is a c40 and I had it working outside all last winter....no issues that I could tell.
chris
# Posted: 20 Jul 2013 03:10am
Thanks!
# Posted: 20 Jul 2013 01:29pm
Just keep it dry and there should be no problem but I do see what you saw:
"The ambient air temperature should be between
0 – 40 °C (32 – 104 °F) for best performance.
Safe Ventilation openings on the inverter must not be
obstructed. If the inverter ismounted in a tight fitting
compartment, the compartment must be ventilated with
cut-outs to prevent the inverter from overheating"
Guess they were playing it safe.
chris
# Posted: 20 Jul 2013 11:55pm
Zero C is the freezing temp of water.. not electronics..
Xantrex competitors manuals show operating temperatures much lower than freezing.
It is frustrating that you call "Technical Support" and get someone non-technical, who can't(won't) put you in contact with an engineer!
# Posted: 22 Jul 2013 08:10pm
Quoting: chris
It all depends on the quality of the electronic components and how much of thier ass Xantrex is trying to cover. Solis state electronics expand as they warm. That could cause varied failures depending on the part quality and the assembly quality. Perhaps there will be no problem, but who knows.
Tou will likely get the same answer from a Xantrex engineer, after all his paycheck comes from Xantrex. IMO.
Rossman
# Posted: 22 Jul 2013 08:18pm
I would imagine they'd be concerned with condensation?
chris
# Posted: 22 Jul 2013 11:36pm
Morningstar has these specs... more realistic!!
ENVIRONMENTAL
• Ambient temperature –40 to +45ºC
• Storage temperature –55 to +85ºC
• Humidity 100% (NC)
• Enclosure Type 1 (Indoor & vented),
powder coated
# Posted: 23 Jul 2013 10:52am
Here's what I do to eliminate all doubt, call the manufacturer, saves a lot of second guessing.
chris
# Posted: 26 Jul 2013 10:45pm
Try it! The reason I am on this Blog is that I kept getting non answers from Xantrex/Schneider.
The last was, "we use commercial integrated circuits, they are rated to 0 degrees C so we rate the unit to zero degrees."
# Posted: 27 Jul 2013 05:03pm - Edited by: groingo
If that is what the manual says and what the engineers say then if your getting colder temps you will need to buy one more suited to your conditions, if you do get it and it craps out the first thing that will kill your warranty will be the low temp, pass and move on.
Personally all I have ever used is Outback brand, pricey but has never failed.
Theirs are rated:
Temperature Range Rated
0 to 50°C (power derated above 25°C)
Maximum -25 to 60°C (Functions, but does not necessarily meet all component specifications)
# Posted: 27 Jul 2013 07:11pm
Quoting: chris
seems like an honest answer. maybe not the answer wanted but telling things like they are.
