sharimca10
# Posted: 2 Jul 2013 12:48pm
I would like to know approximately how much would it be to drill a well in otsego county ny on a piece of property 10 acres for a house that is approximately 1200 square feet and has 1 bathroom now but may have another half bath build down the road
# Posted: 2 Jul 2013 12:57pm
wells.....very DEEP subject ..... in the south...a drilled well with pump/underground wire/ and piping to your cabin is $4500 total..
call a LOCAL well company in your area is the best bet!!!!
sharimca10
# Posted: 2 Jul 2013 01:15pm
is that for any well. are there any specifications as to depth width distance ???? this is all new to me
WY_mark
# Posted: 2 Jul 2013 01:33pm
cost depends on depth, what you're drilling through, what you do once you've drilled and other variables that make it nearly impossible to quote.
here an unfinished well costs $17/linear foot. finished is $21 - you gotta have a finished well to use it. I'd kick someone in the knee for a shot at a $4500 well. we're looking at close to $20k for a 430 foot well....IF we can find water the first time.
sharimca10
# Posted: 2 Jul 2013 01:56pm
there ia a spring well (if that sound right) it is gravity fed but I was told the pump is not working and that the there is not enough pressure and I was told I need to drill a well. is there a standard for each county???
MJW
# Posted: 2 Jul 2013 02:02pm
Quoting: turkeyhunter a drilled well with pump/underground wire/ and piping to your cabin is $4500 total..
I wish...hahaha
WY_mark
# Posted: 2 Jul 2013 02:03pm
you are really going to get more and better info with one phone call to a local well driller. it is different everywhere, even within counties.
Martian
# Posted: 2 Jul 2013 03:07pm - Edited by: Martian
Quoting: sharimca10 there ia a spring well (if that sound right) it is gravity fed but I was told the pump is not working and that the there is not enough pressure and I was told I need to drill a well. is there a standard for each county???
If you have an adequate flow of water into the spring box/well, then just replace the pump. If the spring flow won't support your occasional use, but does supply enough for use over time, then put in a float switch and storage tank to pump into. Then, plumb the house from there.
There are many ways to skin this cat (no offense to cat people) that may be much cheaper than having a well dug.
Tom
sharimca10
# Posted: 2 Jul 2013 04:07pm
Ill have to check that out and inquire more Hopefully that will be the answer n I won't have to have a well dug.
lee77
# Posted: 2 Jul 2013 07:10pm
I drill water wells and have drilled a few in otsego county...If you're talking about a seasonal home there may be better options than a drilled well.
sharimca10
# Posted: 2 Jul 2013 08:01pm
This home will eventually be a permanent residence
lee77
# Posted: 2 Jul 2013 08:42pm
In that case the local code folks might require a drilled well. I know they are very strict around Otsego Lake. You might be able to use the spring in the meantime.
sharimca10
# Posted: 3 Jul 2013 01:37am
Thank u all for all ur responses. You all gave me a lot to consider. I appreciate it very much
jrbarnard
# Posted: 3 Jul 2013 06:19am
550 feet to water in SW Texas and looking at 20k for a well
R
# Posted: 3 Jul 2013 10:07am
First thing, talk to some of your neighbors and get some background on the area, then contact several well drillers and compare notes.
If you already have a spring you could create a holding pond, it all depends on what you want and what your pocket book dictates.
# Posted: 3 Jul 2013 10:24am
My well was 178 feet deep and just a steel lined hole in the ground cost me $8000. I do not even have a pump in it, it wil need the pitless adapter, an underground vault for the equipment to keep it from freezing etc. So add another $4000 or so. Expect to pay close to $15K max usually, for everything installed.
Truecabin
# Posted: 3 Jul 2013 11:30am
most properties don't have a spring you are very lucky wells can get polluted and dry up it happens all the time fix the spring then get occupancy and go from there maybe your wallet could dry up too a spring is like money people like wells because they cant just wish for a spring and the county likes wells because it gives them control it has to be permitted
wakeslayer
# Posted: 3 Jul 2013 12:59pm
Our well in No . ID was $10k. Drilled approx 225 feet down, trenched a line up a hill about 500 feet, 1200 gal tank, line back down to a hydrant. Estimate was around $12000, came in at less, surprisingly. Included all; drilling, wiring, pump, casing, water line, etc.
sharimca10
# Posted: 3 Jul 2013 01:17pm
i will find out the exact problem with the sping and if it is repairable. (if thats a word) what type of fixing would be involved
countrydan
# Posted: 3 Jul 2013 02:18pm - Edited by: countrydan
our well in s/w michigan is a shallow well (i think 50' deep only iirc) and would cost us about $4000 to drill again and use all new material per the well company..
so as has been said i would call a local well drilling company and they should be able to give you a round about estimate based on other depths in your area.
id also call your county health dept for the info about the spring water questions you have. i believe they will also need to test your new well water if you have one done.
PA_Bound
# Posted: 3 Jul 2013 06:14pm
Wow... I feel really fortunate when I read these prices. My well is 320' deep, with 63' of casing and a wired 3/4 hp pump plumbed to a yard hydrant. All for just over $5200.
# Posted: 5 Jul 2013 06:35pm
A friend in the SE corner of UT had a new well drilled a year ago. 750 ft was almost $30K for a working well with a solar powered Grunfoss pump
