yankeesouth
# Posted: 2 Apr 2013 10:02am
I have a few questions about off grid water and hot water tanks/heaters. For those of you who don't treat your water through a softener/sand/salt or like process....do you do anything special to prolong the life of your hot water tank ....that is if you have one? I guess I am looking for something fairly simple and inexpensive......homemade even!
I have a well.....water is usually good and clear but nonetheless it's iron based well water. It gets filtered through a sediment filter before entering the tank. I know straight well water cannot be good for the heating elements in a water tank.Other than seasonally draining the tank are there any other steps I can take to prolong the life of the hot water tank?
# Posted: 2 Apr 2013 10:40am
Depending on the well some water makes tank type heaters last longer .I am on well water and have had a 40 galon tank for 35 years i do understand that demand water heaters will plug up quickly with well water.so the thing to do is ask a neighbour, they will know ..
sparky1
# Posted: 2 Apr 2013 11:39am
1, Change the Anode rod in your (Water Heater) every few years 2. Monthly drain off the dirt/lime from the (Water Heater)
yankeesouth
# Posted: 2 Apr 2013 12:11pm
Thanks. I figured there was no miracle solution....I was just wondering if anyone had some success with tips or tricks.
