VTweekender
# Posted: 13 Jun 2012 06:08pm - Edited by: VTweekender
You should be fine with that system with normal use of appliances, thats if you aren't in the fridge every 20 minutes for beer...LOL....also if TV and fan aren't on 24/7......the only thing I would look at closer is the inverter in that package, you want to make sure its a "modified sine wave" inverter, a lot of the 1000's are not...your TV will be fuzzy on a square wave....won't run laptop or other electronics if not modified sine wave...I also think I would kick up that inverter to 2 or 3000....that way if you ever want to just plug in a drill or saw for a few minutes you won't have to fire up the generator...also I would need it 3000 to make my large cup of coffee in the morning (large surge) ...then unplug the maker right after coffee is done.....microwave would make a 1000 talk as well...you would have plenty system to enjoy those thigs as well, but not on a 1000.
