Small Cabin Forum / Off-Grid Living / Water Pump for sand pt.
Aveallc
# Posted: 25 Feb 2012 08:13am
Hello to all,
I'm going to put a sand pt in at our cabin next weekend for showering purposes only. Does anyone have any recommendations on what size pump I will need and will I need a pressure tank. My water table is approx 14 feet at the lowest. I plan on using a 1 1/4" pipe for my sandpoint. I may hook up a toilet if the pressure is good. Also, I run my cabin off my Honda EU2000 generator. Will I have issues with running a pump off the generator of that size?
Thanks for the input.
# Posted: 25 Feb 2012 08:54am
a 1\4 hp piston pump with a 10 galon bladder tank would work the best,but $$$ .a 1\4 hp jet pump will work also but do not let it run out of water for more than 5 min.or it will be fryed ,a restrictor may be needed .A singal line system will work for both . put a cheque velve somewere in the the suckshon line.
# Posted: 25 Feb 2012 10:52am - Edited by: groingo
Looks like you need to get the specs off the pump you plan to use first and also read your Honda manual, it is very clear on its capabilities.
