Small Cabin Forum / Off-Grid Living / Heating & Ventilating 128' Cabin Area.
Herr VOLKMAR
# Posted: 23 Apr 2009 01:24pm
"An 8'x 16', 128-square foot, A-frame cabin on an elevated 3' concrete pin-point pier foundation with a 3'x 6'8" front flush door, one rear 48"x 48"horizontal slider window, and another upper 24"x 24" horizontal slider window for the sleeping loft." -WSDB
Comrades! One of those standard U.S. Stove designs might provide just a little too much heat for my needs up in the Copper River Basin region of ALASKA's rural backcountry. What are your suggestions for the above described "habitat"? Where can I find the best deals for my 128-square foot space? (Heating/ventilation-wise, we're speaking of subzero temperatures and heavy snowfall, so, I don't believe that "opening a window" is a practical solution for me if it gets too hot and smokey inside my A-frame.) Gis Revido!
swanugly
# Posted: 29 Apr 2009 12:53am
there has been some posts in the past about wood heat . this link was for the smallest stove i found , pricy and i don,t know how long the wood will last in the stove .
http://www.marinestove.com/index.htm
here is a bit bigger stove a freind of mine has one and it works real good . a bit of $ but it would give you lots of heat ,
http://www.jotul.com/en-ca/wwwjotulca/Main-Menu/Products/Wood/Wood-stoves/Jotul-F-602 -CB/
this is what i bought but it is only for part time use and i lined mine with fire brick . works good but i don,t know how it would stand up to constant use .
http://www.endurancemanufacturing.com/
CabinBuilder
Admin
# Posted: 29 Apr 2009 09:36am - Edited by: CabinBuilder
Quoting: swanugly
This thread on wood stove heating may be useful, as well as Cabin Heating section on the main site.
Herr VOLKMAR
# Posted: 29 Apr 2009 01:14pm
Comrades, Swanugly & CabinBuilder:
Excellent weblinks, both! The STOVEs I saw are just what I'm looking for.
Plus, I've done the HEATING ESTIMATE for the A-frame I'm going to build and the numbers come out to about a 620,000 btuh (heat loss) for the new dimensions I'm finally settling on: 16'x16'x16' or 256sq.ft.
This calculation is for -50 degrees F with cold floor, ceiling, and glass surfaces taken into account. (Insulation isn't a factor this early in the design.)
"Wow!" I thought at first. "A 620,000 btuh HEAT LOSS! I reckon you can never have too much stove even for an A-frame design." (Being that A-frame cabins retain heat so well, and that my sleeping loft may get really HOT in the Winter, this was a preliminary concern.)
Modified A-Frame Cabin Design.
steveqvs
# Posted: 3 Jan 2010 12:40am
I like the modified A-frame design. Where did you find it?
Herr VOLKMAR
# Posted: 4 Dec 2012 03:10pm
Search-engine result was : "Mother Earth News - Modified A-Frame Cabin" because Ragnar Benson's A-Frame design is a notorious tinderbox fire-trap... Complicated.
