Small Cabin Forum / Off-Grid Living / How do I connect a Dometic 12v Fridge to a 12V Battery?
lhommedieu
# Posted: 19 Apr 2025 10:30am
How do I connect a Dometic DMC4081CFRH 12V Fridge to a 12V battery? I'm assuming that there is probably a fuse needed as well.
# Posted: 19 Apr 2025 11:56am
Here is a link to what I think is the manual for that model...
https://www.google.com/url?sa=t&source=web&rct=j&opi=89978449&url=https://forestriver inc.com/files/Component-Manuals/Appliance/Dometic%2520-%2520Refrigerator%2520Model%25 20DMC4101,%2520DMC4081%2520Operation%2520Manual.pdf&ved=2ahUKEwj7oazJuuSMAxVwMDQIHZvu C-4QFnoECCsQAQ&usg=AOvVaw2GRLBdAb_ZqNWMF3l8g4Ch
socceronly
# Posted: 22 Apr 2025 01:12pm
There are 12v sockets with lead connectors you can get on Amazon.
https://www.amazon.ca/Cigarette-Lighter-Battery-Adapter-Extension/dp/B01MQZ8KFE/ref=s r_1_2?crid=GEQJOH2NHBN1&dib=eyJ2IjoiMSJ9.avbVTFvSyCT-wynt2nyAX56Rh0c2v2bklSqLYoL7COyY 2ruej7hrEpRtckuLa_UyyY81jRy0KE3rXgXPw5YqZrxout66MfU9-LI87ahD93nKuP7IPPc3yNBce9EuCaUQN Y2BwKWB66Tfwu5wshIvHBzgTFoSOSEkqOFBf7Qc5bPNLLR__O4Sx0Q0qHWuNkRBjf7cLGunb1-TEE4NJEtxGr RrG7VLXZSwysvhovQ0V8Gs6wok_CD_H0tlThS0suFwkMeOBb3zphCYDyaxBkcdkAUkXYxat1y0mJBy4FHSYdE .ys1shdy0Ngi68cosaEXn67yKBmbbuNoIU6miw7ABGbc&dib_tag=smacab-20&keywords=12v+battery+socket+a daptor&qid=1745341874&sprefix=12v+battery+socket+adaptor%2Caps%2C87&sr=8-2
socceronly
# Posted: 22 Apr 2025 01:13pm
They also come with inline fuses too.
https://www.amazon.ca/Adapter-Battery-Terminal-Cigarette-Connector/dp/B07P8XSBHR/ref= sr_1_2_sspa?crid=25MZFYP4P4DSW&dib=eyJ2IjoiMSJ9.pkqcl32eNmPkxc13IhczaPKgw5iPww-0K7G_K KzcrALB86UD3dA7gSZ73i3PBuJ_ZOwogdXVfKaYKCBVvYXz11KB_2TRkjVyHFMTWbvbInbAvErfAVXt-8VoxJ i8PueGPsGaUAXDsYDi45nanUSy2g7RbPIw4oONJ0WU6Z6GAh2ZsfEIJGB2icjYlPWqITM6BNRLacYphMJTuta LSHD8H--cSosZ4i5bDa_4QUnlwDV7y8u3S8fkpM6tzwjkRVT_3N0UXYym8j3zpY4W-gx1YjhTGxBjWfGp_okI jwjTaHQ.2RgCbAY8Yq9SqOK5wZGMBXnK5niMEuqw6r1HvIu9FTk&dib_tag=smacab-20&keywords=12v+battery+s ocket+adaptor+with+fuse&qid=1745341960&sprefix=12v+battery+socket+adaptor+with+fuse%2 Caps%2C70&sr=8-2-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1
# Posted: 22 Apr 2025 07:38pm - Edited by: gcrank1
Fwiw, I dont have one but have messed about with a lot of stuff.
Be aware that the type of connector, wires and fuse will depend upon the max load the unit will draw. Use At Least the gauge and type wire the manufacturer recommends!
Looking at the document provided above I see that they have conveniently provided +/-/grd terminals to attach to. They also tell what wire and max length you should adhere to.
With that in mind, connect to your battery (bus bar?) with Ring Terminals properly crimped to the wire, dont use 'gator clamps'.
A fuse should be within 6" of the battery +. I like MRBF fuse blocks.
