Small Cabin Forum / Off-Grid Living / Off Grid Well Water Pump and Water Filter
MimiInWi
# Posted: 13 Jan 2025 09:18pm
Hello Folks,
I am in Central Wi. I have an off grid cabin. I have the well drilled. Water table is at 11ft (kinda swampy near the property), well depth is 60ft. I am am on solar with a generator back up. My plumber is conventional and not used to identifying low wattage off grid systems. I am looking for 1) a low watt well pump and 2) good water filter. Water filter is important due to the high water table. I have a hand pump now, and it is nasty when if comes out for the first several galllons. My system will be the well pump, then the filter, then a pressurized water tank. Any suggestions are appreciated.
