kittysmitty
# Posted: 5 Sep 2024 01:02pm
Doing a load test on my battery bank 4 Rolls S-555 series/parrell for 12 volts, constant 60 amp draw. The voltage will swing between 11.9 and 12.3 volts, keeps cycling. Any thoughts on this? Thanks
kittysmitty
# Posted: 6 Sep 2024 02:56pm
Hi All I see some views, but no comments. FYI here is the answer I got from Rolls.
"While under discharge, the voltage will ebb and flow; this is normal, and only a four-tenth of a volt fluctuation is well within what I would expect."
offgrididaho
# Posted: 7 Sep 2024 05:15pm
That makes sense to me, straight up voltage readings are really only considered accurate when there's no load anyway, presumably for this reason. Nice to have a manufacturer get directly back to you, +1 for Rolls.
