optimistic
# Posted: 5 May 2024 05:04pm
Hey
I have a 350 gallon underground cistern. It is catching rain off my metal roof. Been doing it for 10+ years. The water is always pretty clear with a tint of tannin from leaves... I have it running through a 3 stage filter with a UV light that runs into an indoor tank I then pull from for showers and so on..
I recently had some work done and my roofer removed my foam and protection from my gutters... The water now is quite dark. Like a pond.
Obviously I am installing back the foam and protection asap but should I be concerned with the water now?
Should I do anything to it?
# Posted: 5 May 2024 08:25pm
Is your roofer insured?
# Posted: 6 May 2024 10:10am
I would pump it back out and start over.
I'm not sure if a roofers insurance is going to cover dark water in a cistern.
# Posted: 7 May 2024 12:16am
My take is that if somebody makes a problem they have at least some responsibility for it.
# Posted: 7 May 2024 03:55am
Re read the contract you signed. If they did what was in writing. Then they did what you wanted them to do. Quoting: Brettny I would pump it back out and start over
