Small Cabin Forum / Off-Grid Living / Limit to pump distance?
rachelsdad
# Posted: 8 Mar 2024 04:26am
I plan on mounting my Shurflo next to a 300 gallon IBC tote. The tote will be filled by a pump powered by a generator that will pull the water from the lake when I need to refill the tote, (turned on manually).
The best spot to place the tote is roughly 40' from the kitchen. I will be running a half inch pex line under the cabin.
Anyone see any issue with that distance? Will the pump be able to maintain pressure from that far away?
# Posted: 8 Mar 2024 06:47am
Horizontal distance means very little compared to vertical. Look at the pumps flow/pressure chart to see if it's going to product the water needed. Specs may claim 3gpm and 45psi but that's with no head pressure/vertical rise.
I have found that a 2.9gpm pump is about bare minimum for a shower because of the head pressure.
Grizzlyman
# Posted: 8 Mar 2024 07:37am
No. I have exactly the same setup. It work just fine!
rachelsdad
# Posted: 8 Mar 2024 06:58pm
Brett/Grizz...first round is on me.
Thank you so much!
spencerin
# Posted: 9 Mar 2024 05:00pm
What model Shurflo do you have? PSI and GPM?
rachelsdad
# Posted: 10 Mar 2024 09:11pm
Shurflo 4028
Danielims
# Posted: 29 Mar 2024 12:36am
40 feet shouldn't be a problem for maintaining water pressure with a properly sized pump. Just ensure the pump's specifications match your distance and desired flow rate.
rachelsdad
# Posted: 30 Mar 2024 05:39am
OOPs 2088, 45 psi with 3gpm.
Heding up Thursday to open early. I'm in the direct line of the total eclipse!!
