# Posted: 4 May 2022 11:37am
Reply Quote
Got this switch, 12 both AC and DC so it says. How to I wire it to a DC battery? The arrow on the switch says Lighting, in case you can't read it. My guess is white to battery +, black to battery - and light -, red to light +.
The diagram underneath must be fore an additional switch, firing line, zero line?
travellerw
# Posted: 4 May 2022 12:23pm
Reply Quote
Ok.. I'm a little confused.. Is this a photo sensitive switch (turns on in dark and off in light)?
How I interpret it for DC! The "white" line is battery negative and you want both supply and load to connect to that terminal (negative from battery and negative from light).
The positive from the battery goes to the "firing line/black" and the positive from the light goes to the "load/red" terminal.
When the switch activates it will connect the "firing line/black" and the "load/red" terminals to turn on the light.
# Posted: 4 May 2022 01:01pm
Reply Quote
Hmm, that's different from what I was thinking. Here is the link to the dingus.
https://tinyurl.com/yey5eb5v
BRADISH
# Posted: 4 May 2022 01:02pm
Reply Quote
Quoting: travellerw How I interpret it for DC! The "white" line is battery negative and you want both supply and load to connect to that terminal (negative from battery and negative from light). The positive from the battery goes to the "firing line/black" and the positive from the light goes to the "load/red" terminal. When the switch activates it will connect the "firing line/black" and the "load/red" terminals to turn on the light. I concur with this take.
Nate R
# Posted: 4 May 2022 01:24pm
Reply Quote
I agree with BRADISH and travellerw.
# Posted: 4 May 2022 02:07pm
Reply Quote
Agree with the crowd.
# Posted: 4 May 2022 02:43pm
Reply Quote
Yep, that works! Little strange hooking the black to DC+. Now I just have to remember why I bought it.
Thanks guys!
