# Posted: 13 May 2011 01:20pm
I need help determining an alternative heat source for my cabin up in Michigan. I was just told by my Cardiologist and Pulmonologist i cant breathe air heated by a wood stove ( i have issues since the heart attack) Ive determined Electric heat sources are more expensive...... although they would work fine. I guess i could invest in one of those Radiant electric heaters that look like a radiator. The cabin is only 400 sq ft. Ive read about Solar Energy for heating a home...... but the expense is crazy. I would really appreciate any suggestions. Lisa
# Posted: 13 May 2011 01:37pm
direct vent propane
# Posted: 13 May 2011 01:50pm
We heat our place with 4 electric base board heaters .700 sq feet . we open the place march 15 and close nov 15 > 856$ last year at 8 c a kwh two fridges and electric cook stove . simple clean safe >
# Posted: 13 May 2011 01:54pm
Thanks !!! I will look into both options.
# Posted: 13 May 2011 10:03pm
We heat with electric baseboards and have programmable thermostats. Setting the thermostats lower at night while we are sleeping helps keep costs down.
larry
# Posted: 14 May 2011 09:41pm
Quoting: naturelover66 I was just told by my Cardiologist and Pulmonologist i cant breathe air heated by a wood stove is there a danger in breathing the air heated with wood. In my opinion electric heat would be cheapest per BTU
# Posted: 15 May 2011 08:31am
No danger for the average person.......... i had open heart surgery two years ago and as a result have heart damage and COPD. My lungs can not take "fumes, high heat or smoke"....... I guess i will go with Electric......... even though its more costly.
Kithera
# Posted: 16 May 2011 02:45pm
The question really should be what do you have to heat with. Electric heat via on-grid energy is usually pretty reasonable as far as cost, and super easy to setup.
If you're off grid and on a tight budget, look for a vented propane heater. The kind which take combustion air from the cabin exterior and put it back when its done. A bit more expensive, but it's a lot easier to lug propane that run a hundred mile extension cord.
Finally, if you want to be off grid and are willing to make a bit of an investment, look a liquid based radiant floor heating. With this system, a series of tubes are placed just below your floorboards, and a hot liquid (usually glycol) is pumped through them. This liquid can be heated using solar water heaters, and the newer evacuated tube kind provide abundant heat even in very cold regions. A propane on demand heater should be used as a backup. As you can imagine, it's a massive job to retrofit, and requires expensive store bought components (sorry, DIYers) but for new construction, it's the best long term solution.
# Posted: 16 May 2011 03:15pm
Yep........ i read a bit about radiant floor heating....... not an option right now. The cabin is wired ......... electric heating is the way i have to go right now.......... eventually...... solar. Thanks for your input. Lisa
soundandfurycabin
# Posted: 16 May 2011 05:18pm
Electric baseboards are cheap to buy and install, and make a good extreme-weather backup to any other system. You could look at adding a solar air heater later. They can be a DIY project; look for plans online. This page compares a few different types:
http://greenterrafirma.com/solar-air-heating.html
