Small Cabin Forum / Off-Grid Living / 50W solar panel
Hangblague
# Posted: 29 Jul 2021 01:10pm
Canadian Tire has a sale on their Noma 50W crystalline solar panel kits. It includes a 7A charge controller They go for $300 normally, now $100. I like that it is compact size - about 27" x 20". It has a stand, but I'd probably prop it instead high up on the south facing gable end of the cabin and connect it to a 12v battery. I haven't tried to do any math, but I'd like to think it would be plenty to stay charged for turning on some led bulbs in the evening and connecting up some usb ports for phone charging. Comments?
Also, I think I'd go with an AGM battery stored inside the cabin permanently, probably up in the loft in proximity to the panel through the wall. I understand AGM is better for frigid temperatures. Comments? (I've never dabbled in off-grid power before apart from running a gas generator).
# Posted: 29 Jul 2021 01:45pm
There are much better deals than the Canadian tire sales but if you think 50w is enough (it’s not much) then it’s a simple option
No need for agm. Normal lead acid deep cycle batteries work just fine for a little system like that. But I’d leave them outside the cabin. No need to keep them warm. Just keep them fully charged
Caution though. Dabbling in solar leads to a long road as once you have power you will want more and will have to keep upgrading
Hangblague
# Posted: 29 Jul 2021 02:13pm
Thanks for this. Are there cons to interior battery storage? I was thinking of proximity and wiring convenience rather than warmth.
# Posted: 29 Jul 2021 02:46pm
[quote=Hangblague]Are there cons to interior battery storage?
AGM and FLA they should be in an enclosed box and vented. AGM does not generally release as much hydrogen gas as FLA but still does.
gwindhurst
# Posted: 29 Jul 2021 05:54pm
I started with a small system; 100w panel, 10A PWM CC, 100Ah AGM, then added another 100W panel... I quickly realized power requirements beyond "my" basic needs. I added 2 more panels, another 100Ah AGM and was forced to upgrade the CC, wiring, inverter etc. etc. etc. Build a system larger than you think you need with a CC even bigger to allow for expansion. keep in mind, you'll want more in the "tank" for cloudy days and panels that can top the batteries off ASAP when you do have sun...
# Posted: 29 Jul 2021 06:42pm - Edited by: gcrank1
You can charge your usb stuff with your vehicle cig-lighter (and I hear some have usb ports too) or get one of those 'power sticks' to take with you after recharging at home. They will run other usb stuff too.
For led lighting look at the 'Edison' bulb solar lights on Amazon. The come in singles and triple packs with their own little solar panel, disconnect so you can hang or carry them anywhere and throw off a decent amount of light. We keep a 3 pack going in the south window as our 'back-ups', they are about $10 per bulb and Im satisfied.
That gets you usb and led light for cheap now while you learn more about what to Not Throw Money At in self solar electric generation plus are usable in other times and places.
# Posted: 29 Jul 2021 06:55pm
If your just charging a few devices and need a few lights for a couple of hours I suggest getting a portable battery bank. A bank that can charge your cell phone say 3x, some 12v vehicle jump packs can do this no problem. For lights led lanterns with rechargable batteries work fine. Or wire up 12v lights and plug them into your portable jump pack.
If I didnt want to run a fridge I would prob just get one of these solar generator battery packs and charge it at home.
Hangblague
# Posted: 29 Jul 2021 07:20pm
Thanks all for the ideas. This has given me more to think about. I like the idea of light wiring with fixtures instead of portable sources. I was also thinking of wiring for DC fixtures and forego the inverter. I get that some day I'll likely wish to have more, but I'm willing to learn the hard way.
# Posted: 29 Jul 2021 07:41pm
I have the predecessor to that unit .I is forty watts and a 7 amp controller. We run some 12 volt lights, 12 volt water pump ,tv ,radio,small inverter150 watt.about 6 hr. A week .
105 amp hr. Wallmart deep cell ,in a vented box. Very happy all we need. Good luck.
travellerw
# Posted: 23 Dec 2022 04:01pm - Edited by: travellerw
If you have an unclewiener warehouse near you, you can get a much better deal. For $110 you can get a 100W, or $199 for a 200w panel. I think you will be much happier with a 200W panel. Especially in winter. My 360W panel produces less than 20W on overcast days.
Another option is Facebook market place for a used panel.
Now with all that said, I completely agree with a power station for your needs. Simple and just works without worrying about venting.
# Posted: 23 Dec 2022 05:31pm
At this point Ive 'dim' (done it myself):
Micro Solar) 15w '12v' panel, no scc, an old 20Ah sealed LA (for a theoretical max of 10Ah usable but really less, like 4Ah. Its an old 'jump-pac' unit).
The panel at 17-18ish V and just over 1Amp output at best, maybe 3hrs of sun on a good day does not seem to hurt the battery. It is my basic, low draw device and LED light unit. This is so handy I should buy an LFP battery to fit in it. A 50w-100w panel would be great, the 15w is basically a trickle charger @ 3/4A output (or call it a toy?)
Mini Solar) 2x 102w 12V panels in series for 24v into mppt scc, output 12V to 100Ah 'marine dc' battery (for a theoretical 50Ah max usable; certainly good for 25-30Ah. It runs the cabin 300w psw inverter fine for LED lights, usb chargers, power tool recharging, small fan, etc of a typical evening and the next morning and recharge that day by 1pm when I lose my sun.
Upgrade Mini Solar) 4x 102w panels, 2s/2p; same equipment but 2x 100Ah bats. Lasts longer or use more loads, still recharges the next day if decent sun to 1pm. Im confident this would support a 500w psw inverter.
Small Scale Solar) 6x 102 panels, 2s/3p, 50A mppt scc, same bats (though now I have 2x 100Ah LFP bats to use but havent charged them off the array. I have used them to power the cabin, Wha-Hoo, Love Em! I can power a 1000w psw inverter now.
For bang for the buck I suggest doing a min. 1000w array wired in series for 24v to an mppt and keep output at 24vdc to a min 200Ah LFP bat-bank. Get a 24v to 120vac psw inverter with a 'grid/gen' input and 'passthrough' 120 and preferably a charger included so it will be charging the bat-bank whenever grid/gen input is available.
