vidaliaman
# Posted: 2 Mar 2021 10:29am
has anyone tried to charge a battery reversing a trolling motor? i'm sure there are some adjustments to be made
dave
# Posted: 2 Mar 2021 10:55am
Seems to me that "wheel" has already been invented.
Basically, a wind generator is a motor in reverse. Ditto a water generator. Etc.
How are you intending on turning the motor/generator?
vidaliaman
# Posted: 2 Mar 2021 11:41am
i have a culvert emptying out a pond that is fed by a fast moving stream, my thoughts were to hook trolling motor to emptying end of culvert, allow stream to turn blade, use current to charge 2 deep cycle batteries,
# Posted: 2 Mar 2021 11:54am - Edited by: gcrank1
Ime (from trying to build a small windplant long ago) the small (tiny really) amount of amps generated would be so small as to, at best, only provide a trickle charge which wont actually 'charge' the battery(s) but maybe keep them topped up if already fully charged. Just like a little 10-15w solar panel on a car dash for a car in 'storage' can really only keep up with the self-discharge over time. If you have enough flow you would be far better to build a hydro out of a 12v car generator or alternator but keep in mind they have to spin fast enough to put out at least 14.5v. You can test spin & measure output on the bench then try to figure out how to drive that fast to make the cut. Also, the more amps generated the more they 'load' the driving force; ie, they get harder to spin the more they generate.
vidaliaman
# Posted: 2 Mar 2021 11:55am
i hooked a drill to the prop shaft and got 4 volts full blast and 2 volts at half speed, what do in need between the motor wires and the 12 volt battery to make sure battery is not over charged? new at off grid battery charging thanks dave
# Posted: 2 Mar 2021 12:03pm
The 'generator' has to put out more volts than the batteries to make them take a charge. That is why a car puts out 14-14.5ish volts for a 12v battery. At 4&2v you might charge a cell phone with a usb port.
Once the system was putting out enough volts to be used for charging, then the same type of charge controller that is used for a wind turbine, along with the dump load would be needed to prevent overcharging. But first you need to see if the moving water can actually spin the motor-generator fast enough to do much of anything.
vidaliaman
# Posted: 2 Mar 2021 12:13pm
great info, so i need to get greater than 12(13 or so) volts from motor to start with, if this is achieved then look for a controller and dump load?
# Posted: 2 Mar 2021 12:40pm - Edited by: gcrank1
It actually needs to output 14+v, a '12v' battery is a nominal voltage, a typical 12v lead acid battery is fully charged when at 12.8v. Your 'generator' needs to have overhead above that. A typical auto gen or alt puts out more than that and the regulator (or reg/rectifier for a alt) brings it down to the 14+.
# Posted: 2 Mar 2021 12:41pm
If we are talking about recharging a 12-volt lead-acid battery then you need to be able to push 14.4 volts or so into the battery to achieve a "normal" charging time. A lower voltage will work, it takes longer. Since this would be running 24/7 you could likely get away with a little less. That is why PV panels sold as "12-volt" panels actually put out about 17 in bright sun. There are losses within the charge controller.
vidaliaman
# Posted: 2 Mar 2021 12:55pm
thanks you guys you have answered some very basic question for a beginner
vidaliaman
# Posted: 2 Mar 2021 01:00pm
i found a treadmill motor i was able to get to 13v's, i will keep on working on it, thanks again
# Posted: 2 Mar 2021 01:51pm
https://permies.com/f/110/hydro
https://www.youtube.com/watch?v=0ieFZI4-6K8
# Posted: 2 Mar 2021 01:52pm - Edited by: ICC
Oops, that ended up a duplicate
# Posted: 2 Mar 2021 03:17pm
Front load washing machine motors are a good choice for this type of generator. They have alot of coils so dont need to spin fast to make power. Then you put the 3ph AC voltage through a rectifier and a charge controller and your all set.
If your making this powered by water flow out of a culvert you could do something a bit different with the dump load. You could make a diverter so the water dosnt hit the wheel when the battery is full.
# Posted: 2 Mar 2021 05:25pm
If I had a flowing stream I'd build a water wheel, always wanted one for some reason.
But you could always just buy one of these https://www.waterlilyturbine.com/?fbclid=IwAR1wEMmAYhjyvgURJeZ9RLsDwSCaCB5ZiD6snQagLQ 69DPh7O32g0IZXLPA
