Small Cabin Forum / Off-Grid Living / Ceiling Fans
# Posted: 2 Feb 2021 10:31am
My cabin came with one, a 120vac typical, cheap, house type, mounted up but not wired. When I decided on using only 120vac inverted from my bat-bank I wired it up and found it runs slower and 'growls' on msw inversion, just fine on psw.
I wondered how much juice it uses running, not the start up since that is short, and I dont have a Kill-o-watt meter.
I found this article online from Jn 29, 2019 on the afresherhome.com site:
'How much elec does a ceiling fan use'
It is very good.
Short story is that motors that run stuff like a ceiling fan need to be 'power factor corrected'; ie, add some more amps draw because creating the magnetic field for the motor to make it work takes more than the label indicates (a PF chart for some appliances is inc.). Imo the author used a decent methodology for his testing and PFC his fan used:
Low 12w 0.17a
Med 42w 0.58a
High 47w 0.65a
All under 1amp at 120vac, thats pretty good.
But, for us off-gridders who are inverting off a bat-bank, often 12v we need to multiply those amps draw by 10 (12x10=120) and factor in the inverter efficiency (mine is rated at 85%) to see what we are really pulling off the bat-bank.
Thus, at 12v, the fan draw rounded up (I always round up for draw calcs):
Low 0.17a x 10 = 1.7a + 15% = 2a 'real world likely'
Etc.
Yeah, not all fans are going to be the same, either, but this gives me a better sense of how to figure my bat-bank sizing and dod, etc. while I contemplate from my easy chair this winter.
# Posted: 2 Feb 2021 06:57pm - Edited by: Steve_S
I will point out that Modified Sine Wave is never recommended for ANY type of motor. Yes they may run, yes they will "growl". They will run at 2X the temperature & heat up quickly, it will shorten the lifecycle greatly and the feedback in the circuits will be "felt" by everything else on the entire electrical system.
BTW: If using a Mod Sine Wave Inverter, look at your lightbulbs... see what an Incandescent & an LED bulb do then compare with how they perform with Pure Sine Wave.
A vast majority of Inverter Generators are also only Modified Sine Wave, only a few like Honda (and that level) are Pure Sine Wave.
Pure Sine Wave is also a tad odd, as there is Low Frequency & High Frequency variants. Low Frequency with large copper wound coils are the most suitable and can typically handle 3X surges. So a 2000W LF Inverter will do 6000W surge handling while a HF Inverter will only do 2X surge handling. There are also Caveats to HF and Motors, see below.
https://www.magnum-dimensions.com/knowledge/high-vs-low-frequency-inverters/inversion -methods-explained-high-frequency-vs-low
# Posted: 2 Feb 2021 07:48pm
Quoting: Steve_S
Yes, that is very true but it does seem to be ignored by many people much of the time. Microwave ovens don't work all that well on MSW either.
# Posted: 2 Feb 2021 08:02pm
Ohhh My, you mentioned the Nukelators !
I did it ONCE and that was once too many times for the Panasonic Inverter Nuker - it never worked properly again and went to trash. Had to, it was an emergency situation and I used a 3kw "Car Inverter" thinking it would be ok... WRONG ! 90 seconds and it was finished.
# Posted: 2 Feb 2021 08:23pm
So what does run on MSW correctly, anything?
# Posted: 2 Feb 2021 09:07pm - Edited by: ICC
Incandescent light bulbs, resistance element heaters that sort of thing. No motors, no electronics. Though it can also depend on the item, the way it is made, type of motor. I gave up on MSW years and years ago.
Everything we buy that operates on house power is designed for use with power grid pure sine wave power. Some things just complain more on MSW or refuse to work or get damaged.
scott100
# Posted: 6 Feb 2021 12:15am - Edited by: scott100
For the ceiling fan we use most of the time, we sprung for a energy star rated dc motor unit. It is a lot more efficient than a standard ceiling fan, but at low speed a standard ceiling fan isn't exactly an energy hog either, as you found out.
Funny thing about microwaves. We have an Aims 3000 watt pure sine inverter. I noticed the clock on the microwave loses several minutes a day. Weird, I thought, so I measured the inverter frequency. It's just a tad less than 60 hz, off exactly enough to account for the missing time. Not off enough to be out of the allowable error in the spec sheet, so it was a keeper, I guess.
# Posted: 6 Feb 2021 04:04am
The AIMS are not actually outputting exactly 60Hz, which you can easily verify with a Kill-A-Watt meter which shows the Hz of the 120V line.
Over 60Hz, clocks = faster.
Under 60Hz clocks = slower.
If using a Genset to charge batteries & provide passthrough, the inverter/charger will pass through the Genset Hz Frequency as well. so if the genset is running at 62Hz your whole system will see that while the genny is running & charging while also providing passthrough power.
Lower Cost Inverter Generators which use High Frequency Pure Sinewave electronics can also vary in Frequency beteween 58-62Hz pending on loads and electrincs quality.
# Posted: 6 Feb 2021 10:52am
Does that mean my 700w $50ish when new microwave will likely die a premature death running exclusively on my inexpensive Champion 2000w (1700 continuous) psw inv/gen?
# Posted: 2 Apr 2021 02:34pm
Ceiling fan time for me too since I'm working up there (15'). Ran wiring yesterday.
I was thinking 12v but I don't see any on the market with lights. Plus they are $100-$150 (I have one of those small cheap 12v jobs elsewhere, works good but too small for this ceiling).
Also have an AC house one, the big brass things with lights that looks like it belongs in the Versailles and weighs 50lbs. That would look OK up there. And I now have a FSW inverter. Maybe that's the plan...
# Posted: 6 Apr 2021 07:25pm - Edited by: gcrank1
This past week I became convinced I had a battery issue. During day use of the fan Ive been having the bat-bank depleting, that should not be on a sunny day! The solar should easily be running the cabin light duty loads with no bat-bank drain whatsoever, leaving a full bb for evening use.
A load tester was borrowed and one of my 2 big, old agms is toast, the other tested quite good yet. The bad one was compromising the good one, just like those in the know say (duh on me!, but I had wanted to see how far I could go with these).
Removed the bad one, the good had a solid day of prime solar charging and the next day until 11am, cc was on float when we arrived and bat tested fully charged, I switched on the 300w psw inverter.
I turned on my little fan and 2 led 9w 120v lights then checked the cc panel. The change from no load to that load read 3.2amps, close, but less than I had calculated (great!). That was all being driven by the solar, no discharge on the battery at all.
We left about 5pm, I shut down the loads at 4 pm and always discon the inv., we would have had a full bat for the evening hours (and we have no overnight loads).
This is a pretty bare bones set up but comfortably adequate. Knowing I can read my loads when I have a fully charged battery will be handy.
One may ask,"how do you know you didnt draw some off the battery?" Well, that hour between 4 and 5pm the battery was in a resting mode, no load (other than being hooked up to the cc which has a small draw), no charging taking place. When I checked it at 5pm with my multimeter it read 12.9v. That says fully charged at rest to me.
# Posted: 25 May 2022 07:15pm
Two day heat wave going on here. And I just realized the new ceiling fan I put up over winter is spinning clockwise, drawing air upward. Innernet says other way for summer, but the switch is 15' in the air.
Does it really matter? I'm not dragging that big ass ladder in here today.
# Posted: 25 May 2022 07:32pm
In a perfect world with the windows open top and bottom you should draw in the lower and out the top....the moving air will feel better than no air moving anyway.
Ive done it both ways when we had an Aliner camper with the 3sp/rev 'Fantastic Fan'. Just having air moving over my skin felt good. If really hot spritz yourself with a spray bottle of water too.
jhp
# Posted: 26 May 2022 09:09am
I think the most important thing is move the air. So first of all have a fan and turn it on.
That being said after my significant personal testing is that it does matter. For most of the year I have my fan set like yours, to push up to the ceiling. This helps keep air circulated more gently and pushes the warm air down along the walls without being breezy. Try it sometime, turn on the fan and put your hand on a wall and you can feel the air coming down.
For the hot months set them to run counterclockwise and blow down. The cooling effect of the air on your skin makes it feel cooling, and the effect is even more if you do have air conditioning. Now if you're not sitting directly under the area of the fan it doesn't matter as much...but if it's right overhead you want it blowing down on you.
# Posted: 26 May 2022 10:29am
Thanks guys. Heat wave is over, down 20F today, but 90 in May, shaping up to be a hot summer so I'll get up there and switch it. I'll have to find another reason to drag the big ladder inside since I'm working 'older and smarter', supposed to be anyway. I do see some cob webs..
I do have it balanced pretty well, using the coin taped to the fan blade method, just a bit of shake. They should have some kind of dynamic balancing for these things.
I have one of those battery powered, hand held spritzer fan bottle things for emergencies.
# Posted: 26 May 2022 05:05pm
Going to cabin tomorrow for the weekend. I recently got a Fluke ac volt/amp clamp meter so I can grab through either fan wire and get a reading on each speed setting as delivered.
Ive got some imbalance, need to try the coin trick.
# Posted: 26 May 2022 06:52pm
That'll keep you entertained for awhile. There may be a more scientific method but what I do is move a light coin from blade to blade, find the one that helps most then move it in or out, then a lighter or heavier coin if needed. Attach it good, the heat can dry the tape and the coin fly out.
When I was a teenager I worked at a small time tire shop. Spin balancing was fairly new, and done on the car. The balancer replace the hub cap and had knobs you held while it was spinning to adjust the weight. For the fronts there was a machine that spun the wheel but for the rear we'd put a floor jack under the rear end, no jack stand, the boss would get in the car and get it up to 65mph. Meanwhile I had to kneel by the spinning wheel, one hand on the car to monitor the shake and the other adjusting the knobs until it was smooth. Sometimes it shook so hard it's a wonder the car didn't come off the jack and shoot out the side of the building. We also did truck slit rims with an axe and no cage. The good old days, we somehow lived through.
# Posted: 26 May 2022 08:12pm
I'll give your tips a go
Years ago I had a bad tire, figured it was maybe a bad belt but couldnt define which one. It would shake about 55mph; so I had my gf drive at 55 while I hung out different windows watching each wheel.....
Its a surprise most boys survive their youth.
# Posted: 28 May 2022 09:39pm - Edited by: gcrank1
Lol, every place I taped a dime on the four blades in a variety of places the thing ran worse than without.
The Fluke says the fan on 120vac pulls .3A on high, .2 on med and low. That translates to (call it) 3.5A and 2.5A off the bat figuring for 'losses' through inverter, etc.
Discovered one must keep the clamp from being too close to the other wire or the reading drops as the other wire cancels out the test wire.
# Posted: 29 May 2022 09:10am - Edited by: paulz
Must not be that bad then. I can't stand watching a wobbling fan. I had one that needed coins on two adjacent blades. You could try swapping a blade around.
I haven't measured mine's current draw, it doesn't even register on the inverter display.
I ended up, the other day, digging out a little USB powered desk fan and mounting it on the shelf above the bed. Small draw, big improvement.
