HHH
# Posted: 11 Oct 2020 06:47pm
Hi new to this site. I have a small cabin 400 sq. ft. My builder installed 3 power outlets. A light switch that will turn on fan with a light. He is not a electrician. There is wires hanging down under my cabin, I want to use a generator now and then. How and what do I need to set this up pictures would be great. Thank you HHH
# Posted: 11 Oct 2020 07:01pm
Quoting: HHH pictures would be great.
I'll start, welcome! ... yep pictures would be great I think we need to see these wires... if possible from where they start to where they terminate under the cabin.
# Posted: 11 Oct 2020 07:56pm - Edited by: toyota_mdt_tech
Also, if its not finished on the inside, I would suggest a small inside panel, run circuits from that to your lighting and outlets and then feed the panel with an input from your generator using an inlet.
HHH
# Posted: 11 Oct 2020 08:56pm
The inside is finish. When I go back I will take pictures.He the builder installed power boxes in the wall then the wires went through the floor. So what do I connect the wires to a fuse box?? or what type of box ?[b][/b] HHH
# Posted: 11 Oct 2020 09:22pm
You have to tell us exactly what is there now. Pictures will help a lot. The better the info you supply the more accurate the responses can be.
# Posted: 11 Oct 2020 10:56pm
I will wait to see what you have now, and we can all pitch in and go from there.
