Lumber
Lumber's nominal dimensions are larger than the actual standard dimensions of finished lumber. Historically, the nominal dimensions were the size of the green (not dried), rough (unfinished) boards that eventually became smaller finished lumber through drying and planing (to smooth the wood). Today, the standards specify the final finished dimensions and the mill cuts the logs to whatever size it needs to achieve those final dimensions. Typically, that rough cut is smaller than the nominal dimensions because...â€
“As previously noted, less wood is needed to produce a given finished size than when standards called for the green lumber to be full nominal dimension. However, even the dimensions for finished lumber of a given nominal size have changed over time. In 1910, a typical finished 1-inch (25 mm) board was 13â„16 in (21 mm). In 1928, that was reduced by 4%, and yet again by 4% in 1956. In 1961, at a meeting in Scottsdale, Arizona, the Committee on Grade Simplification and Standardization agreed to what is now the current U.S. standard: in part, the dressed size of a 1-inch (nominal) board was fixed at ​3â„4 inch; while the dressed size of 2 inch (nominal) lumber was reduced from ​1 5â„8 inch to the current ​1 1â„2 inch.[11]
“The following paragraph is exactly backwards from North American cultural practices where finished retail and rough lumber share the same terminology, as is discussed in the paragraph after about 'architects, designers, and builders': In rough sawn lumber it immediately clarifies that the lumber is not yet milled, avoiding confusion with milled dimension lumber which is measured as actual thickness after machining. Examples – 3/4", 19mm, or 1x. In recent years architects, designers, and builders have begun to use the "quarter" system in specifications as a vogue of insider knowledge, though the materials being specified are finished lumber, thus conflating the separate systems and causing confusion.
Hardwoods cut for furniture are cut in the fall and winter, after ...â€
https://en.m.wikipedia.org/wiki/Lumber
