socceronly
# Posted: 30 Jan 2019 10:25pm
At the cottage life show, I saw a number of bunkies that were framed, with only T&G siding or the thicker larger pre fabricated logs.
Can you really finish a wall with only T&G? If you don't want any insulation... is there any real downside to this?
I'm talking really small things under 200sqft.
socceronly
# Posted: 30 Jan 2019 10:28pm
Looking at a company like ezlog.ca
Says the wall logs are 1 5/8"
So they just stain these things and that's it?
snobdds
# Posted: 31 Jan 2019 12:50am - Edited by: snobdds
Before sheet wood products, 1x12 on a diagonal gave racking and sheer resistance. The key being the diagonal orientation. I don't see how a tongue and groove wall has any racking strength. It would need some bracing to keep the wall from blowing out with roof weight.
socceronly
# Posted: 31 Jan 2019 12:30pm
The T&G I was looking at is 1.75" thick.
The timber frame I would be building has braces in it at 45deg.
These structures do not have braces, and the 'logs' they use are 1 5/8"
I am curious about putting the T&G on an angle, would that be a problem for water intrusion if it were the wall, like the picture here.
socceronly
# Posted: 31 Jan 2019 10:51pm
Huh, is it me or did they install those cinder blocks incorrectly in the picture above?
They should be on the hole side down/up.
