Small Cabin Forum / Cabin Construction / Drywall in a cabin?
Princelake
# Posted: 6 Jul 2018 07:00am
When I build my cabin I was thinking of drywalling the ceiling and painting it white then putting t&g on the walls. Reading past posts it seems the biggest problem is moisture/humidity with drywall. I came across this product here
https://humidex.com/en/products/garage
Has anybody used one of these? Do they actually work? It senses the moisture and kicks off and on so I was thinking hooking it to a solar panel while I'm not there.
SE Ohio
# Posted: 6 Jul 2018 09:05am - Edited by: SE Ohio
Might use a specialized drywall and avoid the appliance? http://www.small-cabin.com/forum/2_4296_0.html
NorthwoodsGuy
# Posted: 6 Jul 2018 10:30am
Yeah, I know someone with a cabin with drywall, and it definitely is musty. It's why we went with wood paneling everywhere. If you are going to do it, definitely look into a specialty product or humidity solution.
Absolutely
# Posted: 6 Jul 2018 02:36pm
I used drywall in my cabin and bunkie, both unheated and summer use only. I have had no issues.
# Posted: 6 Jul 2018 03:44pm - Edited by: NorthRick
Quoting: Princelake
I really think that is location dependent. Our cabin neighbors have regular sheet rock for several years without problems.
SE Ohio
# Posted: 6 Jul 2018 03:52pm
I have T-11 siding as interior paneling, hard to remove mildewfrom rough surface. Will eventually replace or cover with damp-proof drywall, and paint . Painted drywall should be easier to wipe down occasionally.
SE Ohio
NorthwoodsGuy
# Posted: 6 Jul 2018 04:35pm
Quoting: NorthRick
Totally. And also dependent on cabin size, level of vapor lock, and what the exterior entries are like. Where we are, we get a lot of moisture.
