t_bell40
# Posted: 20 Sep 2017 10:21am
Hi, All. I am wondering what anybody thinks about where to put the space heater for my cabin. I am thinking that I am going to put the heater on one side of the cabin (west side of cabin with the vent pipe rising on that side) and my gas stove on the opposite side of the cabin. ?? The cabin is 12ft by 26ft. Or do most people put the heater and the gas stove side by side. ?? I am thinking with them separate I would have to separate supplies and that way if the heater ran out of lp the stove would still work and vice versa. What say ye all ???
# Posted: 20 Sep 2017 02:26pm
If you are using portable propane cylinders why not use oneof those RV regulators with the automatic changeover from the empty tank to the full one? Then put the appliances on the same wall to make only one run necessary.
# Posted: 20 Sep 2017 06:17pm
How many rooms are there? Loft, ceiling height, roof style? Is there a wood stove as well? Bear in mind that the propane tanks will be outside in a ventilated box so easy access to that is important. I would probably use two tanks (one for each unit) so that you don't use up most of the propane on one and then not have enough for the other when that is on (you'll also get a better idea of how much propane each unit is actually using).
What make of stove and heater are you using?
