# Posted: 27 Oct 2016 07:24am
The Garage Door is likely already at or above the 81" height and with appropriate header requirement, width should be at least 8' (typical door).
Sliding Doors are less secure & much less energy efficient (cooling & heating) that a double French Door while costing almost the same. As you intend to use this as a Guest Room + added privacy potential may be worth consideration, you may look at something such as these http://www.homedepot.com/p/JELD-WEN-72-in-x-80-in-White-Left-Hand-Inswing-French-Pati o-Door-with-Tilt-and-Raise-Blinds-H37797/202205203
I have one similar (Diff Brand & Rated for Canadian Climate) and it is a very nice setup, especially with the internal blinds that don't need cleaning and that don't swing around when you open close the doors. There is a Screen Kit as well that works a treat.
