Small Cabin Forum / Cabin Construction / Log home construction choices, Butt-and-Pass?
KDavis
# Posted: 21 Jun 2016 11:39pm
Does anyone have experience with the Butt-and-Pass / Butt Joint method of building. Seems pretty straight forward.
# Posted: 22 Jun 2016 06:56am
It isn't much more work to notch and pass which helps seal and stabilize the corner better. Sort of depends, that would be about the most basic method.
morock
# Posted: 22 Jun 2016 12:37pm
My place is done that way. I haven't noticed any issues with the corners. It's 5 years young in a few weeks.
# Posted: 22 Jun 2016 08:19pm
Butt & Pass method is as old as the other methods... There are comparisons between methods, pro's & cons etc...
Butt & Pass is less labour intensive for assembly but you have to be spending more time measuring & fitting up... Chinking is often not necessary and pinning every 4 feet is a must. It's fairly common around my area and we have many examples over 100 years old and still housing families quite comfortably.
Nirky
# Posted: 23 Jun 2016 10:15pm
This is the most comprehensive butt & pass log home building site I've found on the internet, check out their guest forum: http://www.buildloghomes.org/
