Smawgunner
# Posted: 27 Jul 2015 03:35pm
What do you guys recommend for cutting singlewall black stove pipe? Hacksaw, tinsnips?
# Posted: 27 Jul 2015 04:00pm
tin snips work, but a small cutting wheel on a grinder or even a dremel will give better results.
beachman
# Posted: 27 Jul 2015 05:44pm
Hacksaw. Once you get through you can twist the pipe and actually cut it pretty quick. Tin snips leave a jagged edge sometimes. Cut as straight as you can and be patient. IMHO.
# Posted: 27 Jul 2015 05:54pm
Very fine tooth blade in a power handheld jigsaw. Bosch makes some superb blades for sheet metal. Very noisy.
# Posted: 28 Jul 2015 07:15am
Quoting: FishHog tin snips work, but a small cutting wheel on a grinder or even a dremel will give better results.
this--a ziz wheel aka cutting wheel on a angle grinder works perfect!!
