spencerin
# Posted: 29 Oct 2014 11:39pm
Can you deliberately install almost any two-handle bathroom faucet with one handle in the closed position, but it actually is open? For example, both look closed, but the right / cold handle is fully open will actually let water through.
22hemi13
# Posted: 30 Oct 2014 06:59am
Yes the stems can be installed backward. Easy way to check it it to put stem in and before tightening just slide the handle on and turn to see if it's correct
spencerin
# Posted: 31 Oct 2014 12:16am
That's what I thought. Thanks for the confirmation.
# Posted: 31 Oct 2014 09:50am
Well, it depends. There are some that have keyed parts to make it impossible to assemble the parts in the wrong direction.
bobrok
# Posted: 31 Oct 2014 11:32am
Don't European lavatory handles turn in the opposite direction?
# Posted: 31 Oct 2014 02:07pm - Edited by: MtnDon
I have not noticed that although that may be because we only stay in older areas with older buildings. I do believe there may be some EU rule that now states all hot faucets must turn the same way. Not sure when/if.
