Small Cabin Forum / Cabin Construction / 16 X 16 Foundation
C_Spon41
# Posted: 18 May 2014 11:03am
Buiding a 16x16 one room cabin should I use deck blocks or 3' deep footings with Quickrete concrete forming tube.
# Posted: 18 May 2014 02:12pm
Your foundation piers will be more stable on the long term if the bottom of the concrete is below the frost depth. What is the frost depth in your area?
C_Spon41
# Posted: 18 May 2014 03:17pm
The frost line is 36"
# Posted: 18 May 2014 03:22pm
You'll be far better off with deep piers. If you just put blocks on grade, those blocks will get moved up and down with the freeze-thaw cycles, throwing your cabin floor, walls and roof out of whack. How long do you want the cabin to last?
Shadyacres
# Posted: 18 May 2014 08:20pm
I would definitely go with piers !
C_Spon41
# Posted: 18 May 2014 08:36pm
Thanks for the advice! I will post progress pictures soon.
