Trapper101
# Posted: 17 Mar 2014 08:16am
I`m looking for plans for a 16x20 adobe/southwest looking desert cabin. Its hard to find plans with such a small Sq. footage.
Thanks for your time
Trapper101
# Posted: 23 Mar 2014 01:47am
If you don`t have plans I will also take photo`s
Shadyacres
# Posted: 23 Mar 2014 05:58am
Not sure if this is something you are looking for or not. I just did a search and found this. Good Luck
Trapper101
# Posted: 23 Mar 2014 08:11pm
Thanks
I seen this one before, looking for something a little bigger,, Its really weird not much out there unless you look above 1200sq ft Thanks again
Trapper101
# Posted: 4 Apr 2014 11:07pm
any one else living out in the desert I looking for some desert cabin pictures
# Posted: 5 Apr 2014 12:26am
We have a desert dweller in here. I think his username is Borrego.
Trapper101
# Posted: 24 May 2014 03:05pm
Trapper101 Any other desert Dweller out there I`m looking 16x20 adobe/southwest looking desert cabin
tichalet
# Posted: 25 May 2014 04:28pm - Edited by: tichalet
I'd say you might have better luck looking for 'casita' plans rather than cabin plans because they're a popular item for people with larger desert homes to build for guests &/or offices.
But 16x20 might still be on the small side even for a casita, so you might do better just researching adobe construction methods and applying them to a floor plan you come up with to suit your needs.
Per your later comments, if what you really want are pictures for inspiration, be sure to use the search terms desert and/or adobe casitas under google images because otherwise I suspect you'd probably just get hundreds of pics of Casita travel trailers in your results.
Trapper101
# Posted: 26 May 2014 12:37am
Ill try that that, good tip
