tinbanger
# Posted: 23 Mar 2010 09:26pm
new here and this will most likely be first of many questions planning to rebuild a 500 sg ft hunt camp in the Ottawa Ont area. I would like to build the camp on a raised platform (apx 24" above grade) to eliminate rot and make camp more comfortable. due to remote location and high amount of rock and roots we will encounter I am thinking we will build on Piers .Dig down to undsiturbed soil ( sand) tamp 6" of gravel , patio stone then concrete block piers. Floor joist will be reclaimed 2x12 spruce joists ( $5 each!) and TG ply floor. suspect we should insulate floor as the camp will be used into November and temperatures cab easily fall well below freezing. fibreglass batts a good idea? this may be all we build this year . we are hoping to reclaim much of the existing camp the following year
Sound good so far ..appreciaet any and all comments
dave
hbarker
# Posted: 23 Mar 2010 10:35pm
Welcome ,,
Sounds like a plan so far.. With the 2x12 fiber glass bats for sure the best and cheapest R-value. shouldnt need more than a r-11? in the floor, Some where is a fella on this site used plywood sheets between floor joist to hold insulation and keep varmits out. maybe tack a 1x2 firing strips about 4 inches from the top and screw plywood to it between the floor joist , That would give enough room for the r-11 or even r-13 batts. Then lay your T&G decking ..
Good luck on your project.
Moontreeranch
# Posted: 5 Apr 2010 06:40pm
I used I-joists, thin 3/8 ply laid and nailed to the tops of the bottom flanges, R-30 in the "bays" then 3/4 ply over the top.
Joists are set on built up beams set on posts on poured footers
pics here
http://www.small-cabin.com/forum/6_169_0.html
MainerinExile
# Posted: 14 Jul 2010 02:17pm
Moontreeranch, beautiful property there, and I liked your construction photos in the link you posted. That looks an awful lot like up around the Buena Vista area, am I close? I am in LIttleton but get up into the hills as much as possible to camp in our RV, good job on the Cabin! Tim
