jdkeller
# Posted: 1 Jan 2014 07:38am
I am going to building a pier and beam foundation and I was curious if I could use pavers instead of brick. I am not opposed to brick, I am just weighing options.
http://www.lowes.com/pd_477061-215-506818_0__?productId=4686285&Ntt=paver&pl=1¤ tURL=%3FNtt%3Dpaver&facetInfo=
Thank you.
# Posted: 1 Jan 2014 10:40am
Piers? You mean on top of the ground? If so, I don't think it matters much, just as long as they're stable.
jdkeller
# Posted: 1 Jan 2014 11:37am
Yes. So basically subsituting pavers for rock or brick when creating the piers (posts).
# Posted: 1 Jan 2014 11:43am
How high above the dirt will the lowest wood be?
They might be stronger, not sure. You don't want them to crush.
jdkeller
# Posted: 1 Jan 2014 12:08pm
The lowest wood will be about a foot, maybe 18 inches. I havent really decided.
# Posted: 1 Jan 2014 12:12pm
The Lowes site you showed was in Northern MN. Is that where you're building?
Owen
larry
# Posted: 1 Jan 2014 12:16pm
i would be wondering more about the compression strength. what is the weight they will be holding?
# Posted: 1 Jan 2014 12:29pm
I've been using cement block my whole life, but I wish you could buy wire re-enforced cement pads. We could make our own.
jdkeller
# Posted: 1 Jan 2014 12:39pm
No, it isnt in MN. I am thinking either Virginia or West Virginia. I havent calculated weight. My initial plan is a 12 x 20. 3 piers width-wise, and 4 pierd length-wise.
# Posted: 1 Jan 2014 01:37pm
I don't think weight/compression is an issue at all with such a small building. Rather, using pavers, bricks or blocks just needs to be done carefully for long term stability. Keeping it 12 to 18 inches off the dirt should ensure that your wood doesn't rot from ground moisture, but I wonder how you will stack the pavers up to that height in a way that will remain stable. I'm sure it can be done, but it seems like you'd need more than a single vertical stack at each bearing point.
Also, you need to ask how deep you will set them in the dirt. To avoid heaving its best to dig to frost depth, or close to it.
Is there an advantage to using pavers over using standard precast piers?
jdkeller
# Posted: 1 Jan 2014 01:51pm
Absolutely, I was going to basically build the posts like an old rock foundation wall using mortar. They would probably be about an 18" square columns.
VTweekender
# Posted: 1 Jan 2014 01:52pm - Edited by: VTweekender
If you are not digging down and using ground level then I would go with pier blocks http://www.homedepot.com/p/Unbranded-6-in-x-10-in-x-10-in-Precast-Concrete-Pier-Block -709537/202564184 ......they are 10 inches high and you set in vertically a preasure treated 4 x 4 for your pier.....set in about 2 foot 4 x4 lengths then you can snap a line for level and cut them....whalllaaaaaa level!!!
you could fancy some stone around them after...looks great...I did it.
# Posted: 1 Jan 2014 10:38pm
Looks like pavers are viable to me. The cost is about the same as bricks, which are about 50 cents apiece, the pavers are twice that price and twice the size, with a very different look. Your 18 inch square columns seem quite adequate. Interesting way to make a pier foundation. Post photos if you do it
jdkeller
# Posted: 2 Jan 2014 03:29am - Edited by: jdkeller
I will, though this project will not be done anytime soon. I am drawing plans and figuring things out, but I will definitely be chronicling it.
