Usa89gt
# Posted: 12 Nov 2013 05:30am
My cabin will be 12 foot wide and I lam looking at ideas for front door and front window/. I like a centred door with a window on either side but unsure of width/height of windows or the width of the door. Thoughts? I like a symmetrical look.
spoofer
# Posted: 12 Nov 2013 03:39pm
go with a 32 inch door the more windows, the less usable wall space
HoosierDad
# Posted: 12 Nov 2013 06:05pm
One advantage to moving the door to one side (rather than centered) is that you gain some extra useable wall space. This can be especially important when furnishing a small space. Just a thought.
Usa89gt
# Posted: 12 Nov 2013 06:27pm
Thx folks
# Posted: 12 Nov 2013 06:34pm
I like doors off to the side in a small building. That is because the door can open against a wall and if left open does not take up much space.
Window tops should align with the door top; visually most pleasing.
I believe there should be at least one 36" wide door in every building; easier moving larger things in and out.
# Posted: 12 Nov 2013 07:26pm
Most building codes mandate a 36" wide exterior door (at least one). Standard height for windows is 80". If you need even more floor space inside you could use an "outswing door".
missouriboy
# Posted: 12 Nov 2013 08:45pm
I'll third the door to one side. My cabin is 12 ft wide and you will want all the wall space you can get.
# Posted: 12 Nov 2013 09:54pm
Home Depot has a 6' wide door with (2) 18" sidelights for $500ish. can't beat the bang for the buck!
