grover
# Posted: 21 Oct 2013 01:44pm
Not really sure if it is the fascia but I'm trying to find out how to install the piece of metal that wraps around the edge of the roof. Especially how to weatherproof the peak where one side of the cabin meets the other. Just overlap and caulk?
Martian
# Posted: 21 Oct 2013 01:53pm
I'll try to remember to take some close up pictures of how I do it. I just finished doing that part on a project.
Tom
# Posted: 21 Oct 2013 03:07pm
Special metal flashings are made for every different edge/intersection that you encounter when installing metal roofing. You can buy those, but they are pricey. Alternative would be to look at the profiles offered and duplicate them, more or less, with less expensive standard flashings you would find at Homeless Despot or elsewhere.
Excellent metal roofing guide:
http://www.bestbuymetals.com/pdf/r-panel-installation-guide.pdf
Main thing to remember is to shingle all layers, upper layers always overlapping lower ones.
Good luck
# Posted: 21 Oct 2013 05:12pm
There is pieces made just for that, also another type if you want a ridge vent. Same goes for the fascia where gutters mount and the gable end fascia too.
Martian
# Posted: 21 Oct 2013 06:36pm - Edited by: Martian
You have residential eave trim and residential gable trim. The eave trim goes under the underlayment, and the gable trim goes over the top of the metal. At the peak, I cut the roof angle in one side, and trim the kickout off back to the where it lines up. Then slip the one side under, and pin it... or not. Make sure the side you slip under is away from the most visual side so it disappears. At the lower end, it just gets trimmed. to fit the edge back to the fascia.
When you order the eave trim, have it bent to fit your pitch. I like it bent just a little less...2 or 3 degrees...so it fits tight with out needing screws.
grover
# Posted: 22 Oct 2013 02:00pm
Martian, your first pic is where I was asking about. I think you are saying the side that goes on first, (usually the rear of the house), is cut at an angle where it reaches the opposite roof line. Then the other piece is cut at a 90 degree angle to the ground. Thanks everyone.
Martian
# Posted: 22 Oct 2013 09:48pm - Edited by: Martian
You don't have to extend it to the roofline...just beyond the intersection an inch or so. The idea is to close the opening so no wood is exposed. The other piece gets cut vertically in line with the fascia joint.
Its really easy if the final piece of trim extends over the top. Then, all you have to do is cut the same angle as you cut on the rafter tails on one side, and bend the metal over the top.
Tom
grover
# Posted: 23 Oct 2013 08:01am
And do the screws on the roof side and on the fascia side?
Martian
# Posted: 23 Oct 2013 08:18am
Yes.
Jim in NB
# Posted: 29 Oct 2013 09:32pm
Habitat for Humanity - just about any chapter - has good info on this. Just google it - they have good pictures too. Mine are down at the camp right now!
