bobbotron
# Posted: 16 Jul 2013 06:59pm
So I'm looking to build an 18x18 foot detached deck in Southern Quebec, nearish to Ottawa (fair snow load in the winter.) It's starting on top of a hill, will be about half on a hill, half drops down to a second shelf about 5 to 6 feet down. I'm thinking it'll have three beams, running perpendicular to the hill. Each beam will have either three or four posts, making for a span of either 9' or 6', with one or two posts on the top of the hill, and one or two down the hill, each at least 4' deep. The deck will be very close to the ground on the top of the hill - basically the beam will rest right on the sonotube.
I'm planning on using 6x6 PT posts, and 8" sonotubes. 2x8 ground rated PT for the deck joists and probably two ground rated PT 2x10's for each beam. I plan on putting the outer beams about 6"'s in for the side of the deck.
I'm somewhat confused about what size of footing I'd need - I've looked at a few span tables and each points to a different size. My dad didn't even use sonotubes for his raised deck at his cabin, but I think I don't want to do that here. I plan on putting a lot of bracing on the lower posts as they will be a ways up in the air, but not nearly as much as some decks near my place. So I'm thinking either no footings or a 14" footing for each tube. Maybe bigfoot footings, but wow they require a big hole.
I have no idea what kind of decking I'll use yet, maybe some kind of 4/3" cedar decking.
What do you think? Suggestions? Something I'm not thinking of WRT to building on a hill?
I need to run all of this by the inspector, but I like to have these things lined up first.
