Small Cabin Forum / Cabin Construction / cabin foundation
<< . 1 . 2 .
# Posted: 3 Jul 2018 03:41pm - Edited by: KinAlberta
Could this spread the load, add more bolts and reduce risk of shear: add more 2x12s on the insides of all the posts, then bolt through both so that all the posts are sandwiched between 2x12s. Then fill the remaining 1”-3” gap between the concrete and the bottom of the new 2x12s with mortar or cement held in place with a metal mesh or wrap.
Everywhere inside the rim joist there would be a gap between the top of the inner 2x12s and the 2x8s that could easily be filled.
I would guess that adding a lamination over the two stacked 2x12 perimeters boards would result in a beam strength somewhat closer but under that of a 2x22” or more beam.
Procraft67
# Posted: 12 Nov 2019 05:35pm
Simple genious idea that I have been looking for, thanks much!!
<< . 1 . 2 .
