Small Cabin Forum / Cabin Construction / 110v hot water heater?
10sne1
# Posted: 22 Apr 2013 07:44pm
I read a thread about a hot water heater that ran on 110v and made at lot of hot water using very little power. I can not find this thread, please let me know what type hot water heater I am referring to?
Thanks
# Posted: 22 Apr 2013 09:07pm
Quoting: 10sne1
lots is a relative term,
water heater speed or capacity is a function of the wattage of the heater element. 110-120 vac elements are usually only 1500 watts with 2000 watts max while 220-240vac elements are around 4500 for normal and run on up to 6000 watts. no free lunch, no way to heat water cheaper or quicker, per volume of water, on 110-120 vac than on 220-240.
Taiwin
# Posted: 22 Apr 2013 10:08pm
Titan water heater?
sparky1
# Posted: 23 Apr 2013 09:35am
How many Watts to heat one gallon of water?
Constants:
One gallon of water weighs 8.337 lb.
One BTU is needed to raise the temperature of one pound of water one
degree F.
3.413 BTU = 1 watt-hour
What's the Temperature Rise?
Incoming water at 50°F to 120°F outgoing is a 70°F rise.
Calculate:
8.337 lb of water x 70°F rise requires 583.59 BTU per gallon.
583.59 BTU per gallon/3.413 BTU watt-hours = 170.99 watts required to
heat one gallon of water from 50°F to 120°F
sparky1
# Posted: 23 Apr 2013 09:36am - Edited by: sparky1
i'm in the process of heating water from a 145 wat 12 volt solar panel to a 12 volt DC element-
# Posted: 23 Apr 2013 10:03am
heating water with sunshine is much more efficient if you use the solar heat to directly heat the water and skip the low efficiency of converting sunshine to electricity. pv panels are still only about 15% efficient. better to use the panle to run a water pump
