Small Cabin Forum / Cabin Construction / sand point/pitcher pump
camp crooked
# Posted: 12 Dec 2012 09:17pm
Ive been thinking about giving a hand driven sand point well a try. How well do these things really work? my cabin is at the highest point of the lot but there are a few areas that might have ground water close to the surface very close to the building. The water will be used for showering/cleaning only. I have been bringing up water for 12 years and with a growing family the water tanks take up more room than the gear bags now. Soil is mostly sand and gravel just below the surface.
# Posted: 12 Dec 2012 10:31pm
if you have sand and gravil you likely have water . i run two full time homes with sand points.. a high spot is often the best spot for a sand point.. ask your neighbours someone will know if there is water around and how deep it usualy is locally , good luck
Scott_T
# Posted: 13 Dec 2012 03:05pm
Quoting: camp crooked
They work very well. I put one in a year ago pounding a 1 1/4" dia. SS pipe 16' into fine sand--pretty easy. Bought a $35 pitcher pump and that's it. Be sure to use a sacrificial striker cap so as not to damage the threads. (PS I used stainless steel pipe because the water is a little on the acidic side where I am; pH ~5.5, but regular iron pipe will suffice if water has pH of 7)
camp crooked
# Posted: 13 Dec 2012 06:37pm
Im confused trying to understand the water ,the high spot is best for water? On the south side of the camp the ground goes out flat for about 25-30 ft and drops off quickly to a seasonal stream (about 25 ft down) North side flat about the same and gently rolls down about 10ft and it rolls back up.Outhouse is to the east. I thought the best spot for a well would be near the stream or to the north side in the low spot. How does water seek a high spot?
Sustainusfarm
# Posted: 13 Dec 2012 07:16pm
Find out how deep the water is in your area first! If it is within 20' of the surface than pound it where it is convienient wheather high or low...How much higher is your high spot compared to your low spot??
# Posted: 13 Dec 2012 07:25pm
camp crooked
Im confused
thats were the sand is the deepest, i gess, works for me.we have one at our cottage[ 7 ft. deep] two bathrooms and a washer a dryer 1\3 hp. pump never run out .. your condishons may be differant ask around local ...
camp crooked
# Posted: 13 Dec 2012 08:37pm
ok thanks.Ill talk to my old neighbor next time Im there. I guess Ill give it a shot in the spring
