Small Cabin Forum / Cabin Construction / questions about moisture and mold in
bukhntr
# Posted: 29 Aug 2012 06:20pm
along with my other question I am also wondering about how to control moisture to not have mold. It will not be climate controlled all the time. I will do some cooking inside which I have read puts off a lot of moisture. Let me know what experiences you have had.
# Posted: 29 Aug 2012 06:42pm
Where is this to be located? Not to spy on you but to determine the climate zone (insulation / vapor barrier climate zone, not the agricultural climate zone.)
bukhntr
# Posted: 29 Aug 2012 11:10pm
southeastern Kansas. As in my other post, I know R-13 is low for the roof, but we have heated a single wall hunting tent with a furnace, so I think we will be ok, even if not the most efficient.
# Posted: 30 Aug 2012 12:53am
Google DIY sparay foam insulation. It's a messy process, best to wear disposable cloths, hair/head cover, etc.
mojo43
# Posted: 31 Aug 2012 09:13am
What about this??
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CEAQtwIwAA&url=ht tp%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3Di1guAwzyEOQ&ei=G7ZAUOmxBYyvygG51ICIDA&usg=AF QjCNF7XEgl7EBl55UKoDyjJB_R9LyIzQ&cad=rja
It doesn't seem to hard..
Bzzzzzt
# Posted: 31 Aug 2012 06:55pm
I want to spy on you! My cabin is in NW Arkansas and I bet we're about an hour apart. As far as moisture goes, i can't help in the least. Electrical is my thing.
Martian
# Posted: 1 Sep 2012 06:19pm
When you cook, open a window. If you use wood heat, moisture is not a problem. I'm in the Flint Hills and haven't had any problems.
I'm actually toying with the idea of using a convection vent over my stove. It would be used mainly in the summer when the A/C is having to remove moisture and will rely on solar heating of the vent pipe to pull the cooking vapors out. In the winter, it would only be used if I burn something. Moisture is in short supply with the wood stove, but if I wanted to vent, the warm air rising should do the job. I'll probably put a rotating cap on the stack to take advantage of the pull from the wind, too. In a small space, even the quietest power vents make way too much noise for my taste.
Tom
