Small Cabin Forum / Cabin Construction / Raised posts?
yana
# Posted: 26 May 2012 12:33pm
Hi all!
I am thinking about setting my (true) 6x6 wood posts on about 3' high concrete pillars, probably made of 4 concrete blocks with concrete poured in the middle. There would be rebar in the concrete and also a bolt to attach the post.I would have to pour the concrete all the way to the frost line, right?
Does that seem like a strong enough way to do this? My cabin will be 10' x18' and pretty tall.
Any feedback?
Thanks so much!
Yana
VTweekender
# Posted: 26 May 2012 12:48pm - Edited by: VTweekender
When you say 3' pillars, do you mean 3' below grade or above grade? If you want to be below the frost line and 3' above grade "both" , I think I would use sono tubes , 8 or 10" wide tubes...you can buy them in the length you will need...pour a footer in the bottom of the holes to foot the sono tubes or just throw a bag of kwikcrete in the hole and let the moisture harden it as footer... And "posts", do you mean upright? or the horizontal runners you will be building your floor joists on...yes you want to get below the frost line..... all in all it sounds plenty for a 10 x 18 to me..
yana
# Posted: 26 May 2012 02:43pm
Hi VTweekender!
Thanks for your feedback. Indeed, I was hoping for 3' above grade and then a vertical post of 9' on top. I have seen the look of a wider base for a post (sometimes out of stone) but wasn't sure how to tie the two together.
The idea of a sono tube about 7 feet long (it's about 4' to the frost line) with a footing makes sense to me. But then how would you attach the post to the top of the concrete? With an embedded bolt? Or embedded straps/ angles? Does that still sound strong enough to you or were you thinking of holizontal posts?
Thanks again for letting me pick your brain!
Yana
VTweekender
# Posted: 26 May 2012 03:20pm
Hi Yana, yes I would use a bolt like you were thinking originally, I assume these will be structure posts of the cabin? and you will be tying them together somehow ....
