Malamute
# Posted: 19 May 2012 12:19am
Is it a re-chink, or a first time chink on the house?
How big is the house? It's likely buying the gun and 5 gallon bucket(s) is more practical and cost effective. You also need the plate that goes in the bucket for the gun to screw in to. It makes it tremendously simpler to load the gun.
I use Log Jam also. Good stuff. Use a high quality spray bottle (Rubbermaid makes good bottles, their commercial ones) with a mixture of 50% water/rubbing alcohol to tool the chink when you put it in. The mixture keeps the chinking from sticking to your tools, and allows you to get a decent finish on it. I use small margin trowels, ground to various widths and lengths. Some use foam brushes, I dont like them, and don't think they allow you to tool the chinking properly. Perhaps the brushes have a place as a finish, but the chinking needs to be tooled to adhere best. Tooling basically amounts to rubbing the material aganst the logs as you work it, just like you rub tape when you put it on something. I've worked on things that obviousy weren't tooled, and the chinking comes off much easier than where it is tooled well. The small trowels, or the little metal tools that sashco or whoever sells will let you tool it well.
