VTweekender
# Posted: 16 Apr 2012 04:18pm
Well Mojo, here is what I would do , if going to move it later I would build it on runners, 4x6 pressure treated runners about 3' apart running the length of the cabin, on top of the runners I would put 1/2" pressure treated plywood, then I would put 2x6 pressure treated floor joists 16" on center, then I would insulate with R-13 between the joists and vapor barrier on top, then whatever you use for subfloor on that. To get level on the slope you mention, I would either just block it up level with 2x8 cement blocks stacked, or dig down and set some 4x6 pressure treated piers, most likely I would just block it knowing I am going to move it sometime down the road.
Best of luck on your project!!
