Small Cabin Forum / Cabin Construction / most affordable water setup
Rifraf
# Posted: 20 Mar 2012 03:07pm - Edited by: Rifraf
My wife and I dont think we can afford our well to be drilled until next year with all the other expenses that are poppingup.. BUT we have had well pump (not submersible ) and pressure tank donated to us.
Was wondering what options you might recommend to use these items, I can have water delivered in the area my cabin is. Are there easy to install holding tanks I could bury below freezing line and run a hose into that ? Any explanations of such setups? Im quite a visual learner and could benefit from any pics of design, or installations if you know of any.
Next year or two we will still have a well put in place, but since we have the pressure tank and pump we thought we might be able to finish the cabin with these items for a year or so of use.
PS.
one question I was curious about was holding tank size , we are a family of 5 (wife an I , three kids ) and would like water to last several weeks or a month if possible.
# Posted: 20 Mar 2012 05:58pm
if you are carefull ,1 gal. per day per person .use lots of handy wipes.outside john .
Rifraf
# Posted: 20 Mar 2012 08:44pm - Edited by: Rifraf
well, we will be living normally, meaning septic will be installed and will be flushing as needed i will be getting a low flush toilet though, should help some.
# Posted: 20 Mar 2012 09:59pm
that 's a big diferance , only experance i have like that is once our well needed repair and we used a water tank for a week or so we [family of 4] used 200 gal per day.1500 gal. tank lasted a week.
Aqua
# Posted: 27 Mar 2012 07:51pm
Look at your on-grid water usage for months and see? 50 per person per day sounds about right, if you are being only a little careful. I know a family using that much, including laundry, showers, dishes. More if you have to fill a hot tub or pool, or water a lawn or garden during a heat wave or drought. Pools, gardens and lawns use way more than you'd think.
