dvgchef
# Posted: 16 May 2009 01:44pm
Greetings all; Am in the planning stages of building a 12'X12' cabin. I can't go larger cause of zoning - the footprint must be less than 150 Square Feet but I can go as high as 35'! That would be crazy, but can I go to 18' high? I'm thinking I would like to have a raised loft area, so the cabin would basically be 1 and 1/2 stories. I'm asking this in regards to structural integrity & engineering POV. any help, past experiences or suggestions appreciated. Thanks! DG
soundandfurycabin
# Posted: 16 May 2009 08:01pm
18' should not be a problem. This tower is 10' by 10':
dvgchef
# Posted: 17 May 2009 06:25am
Thanks! Is this your cabin? must have awesome views! Is that a solar system on the roof? That would be my next step after the cabin and privy.
soundandfurycabin
# Posted: 18 May 2009 03:28am
No, I'm still planning mine. You are right about the solar system...that is in fact the owners' power shed, and my guess is they made it that tall to keep the panels in the sun longer.
# Posted: 15 Sep 2009 11:22am
thats the coolest cabin.i love it.thanks for sharing.cabingal3
# Posted: 15 Sep 2009 09:57pm
If you wanted to use the appropriate footings, posts and engineered beams, you could technically go as high as you wanted..... real footings may not be allowed in your area and it depends on the visibility of your lot...
# Posted: 7 Aug 2010 08:29pm
Quoting: dvgchef Greetings all; Am in the planning stages of building a 12'X12' cabin. I can't go larger cause of zoning - the footprint must be less than 150 Square Feet but I can go as high as 35'! That would be crazy, but can I go to 18' high? I'm thinking I would like to have a raised loft area, so the cabin would basically be 1 and 1/2 stories. I'm asking this in regards to structural integrity & engineering POV. any help, past experiences or suggestions appreciated. Thanks! DG
Usually anything over 20 feet high needs a variance.
