Herr VOLKMAR
# Posted: 23 Apr 2009 01:10pm
An 8'x 16', 128-square foot, A-frame cabin on an elevated 3' concrete pin-point pier foundation with a 3'x 6'8" front flush door, one rear 48"x 48"horizontal slider window, and another upper 24"x 24" horizontal slider window for the sleeping loft.
Foundation: (4) 8"- diameter cardboard cylindrical concrete forms for pin-point piers; (4) 84" reinforcement rods for pin-point concrete forms; (16) Bricks for base of footing; (24) Layout stakes; (8) 5' batter boards; (1) Spool of wire for joining the two 14" reinforcement rods for each footing base; (1) Spool of line for marking building layout lines; (?) Bags of cement; (?) Bags of gravel; (?) Bags of sand...
*A few questions about the amount of concrete needed for the four footings and the four concrete piers: "How much concrete will be needed for four 8"-deep concrete footings poured into four 16"-diameter, 44"-deep holes with each containing four bricks and the four reinforcement rod supports? How much concrete will be needed to fill four 8"-diameter pin-point concrete pier forms to an estimated height of about 80"-inches? How many total bags of cement, gravel and sand (aggregate) will my foundation require? Most importantly, how much will it all cost?"
A-Frame Structural Triangle (Theoretical Dimensions): Sides = 12' Base = 8' Angles opposite sides = 70.529 degrees Angle opposite base = 38.942 degrees Area = 45.255'
Framing: (2) 2"x 10"x 16' girders; (12) 2"x 6"x 12' rafters; (6) 2"x 6"x 8' joists; (4) 2"x 4"x 4' collar beams; (10) 4'x 4' plywood sheets for subflooring; (2) 16' framing braces for structural support against wind damage; (?) 3200-square feet of roof/wall sheathing material for exterior surface areas...
*A few questions about the amount of roof/wall sheathing material needed to cover the 3200-square foot exterior surface area: "How much exterior sheathing will I need? How much will it cost? I understand that metal sheathing is preferred in the Copper River Basin region for its snow-shedding ability, so, given everything I've just said, what are my options for the A-frame I recently designed?"
