Small Cabin Forum / Cabin Construction / 14 x 20 Planning
<< . 1 . 2 .
Hatties Hubby
# Posted: 20 Dec 2010 09:41pm
Generally generators work better at high speed than low speed. The Roman hamster wheel was very low speed. The rollers of a conventional treadmill are relatively high speed. Why not just remove the friction device from a treadmill and replace it with a generator? It might take a bit of playing with gear ratios to get the resistence you like. That could probably be done with stepped (cone) pulleys and a V-belt.
MikeOnBike
# Posted: 21 Dec 2010 02:32pm
This is not an endorsement of specific suppliers, just the idea of a bicycle powered generator.
http://www.pedalpowergenerator.com/
http://www.econvergence.net/electro.htm
waverlyroxane
# Posted: 17 Jul 2011 07:24pm
We have just put in a contract on property near Redfield (we are from MD). Christmas and Assoc is putting in the frame to the cabin. It looks to be the same as yours. I' interested in hearing about how you handle utilities. I'm interested in solar, but we will be in the woods. Is it possible to set a panel up out by the field and run wires, do you think? I'm considering an incinerating toilet, and putting in a well at some point. Just starting to think about these things and wanted to hear our thoughts since you are in the neighborhood.
Jam
# Posted: 21 Jul 2011 11:32am
Your layout is very similar to ours, as is the size of your cabin. We have a steep open staircase with narrow treads(steps) going to the second floor, with a railing made from small stripped branches. What I am suggesting is that it is sort of a middle-ground between a ladder and a staircase. It takes less room than a staircase but is easier to climb and more attractive than a ladder. One warning we give everyone, though, is that they should come down the stairs as if it were a ladder - holding the railing and facing the stairs. That is safer, since the treads are so narrow and it is steeper thana normal stairway. We love it!
# Posted: 2 Nov 2011 02:18am
how abou tbuilding with bamboo and hay or pine needles for istalation
Retired
# Posted: 5 Dec 2011 02:17pm
There are all kinds of cabin plans on the internet, you can find one that will suit all your desires. I paid only about $29 for mine and although the blue prints were fairly simple, it made construction much easier by referring to the plans and not have to guess on how to build it. You also know what it looks like when its done. I fear if you design a floor plan and build from your own plan the outside may look rather boxey. Good luck
Trekermt
# Posted: 18 Nov 2014 05:29pm
I'm new here but have enjoyed reading the information. I'm looking to build a cabin myself. Lots of helpful tips here. Keep them coming...please.
Thanks
<< . 1 . 2 .
