| saltbranch Member
 | # Posted: 8 Oct 2011 11:16pm Reply
 Here is my idea. Build the sub frame with 2" square tubing about 16-18" tall and wide enough to slide up into a 20' Utility trailer(83" inside to inside), and have the floor joists clear the top of the trailers fenders.On top of the square tube frame is where the floor joists would set.Build cabin up from there.(similar to a cab over camper setup for pickup truck beds)
 This would allow me to build the cabin at home, then move to our families property. I am thinking 12' wide and 20-24' long.Using 2x6 joists,2x4 studs for the walls,T-111 siding and metal roof, one room with no interior walls exept for the bathroom.How would you estimate the weight? I have a 12k capacity low profile trailer. Over width trip permits run around 50.00 or so and @ 12' I can get through the gates at our place.
 Thoughts, opinions?
