Small Cabin Forum / Cabin Construction / Window casing/spline question
# Posted: 13 Sep 2011 10:26am
Hello All !
I'm an American living here in Kazan, Russia. I'm from Washington State and married a Russian gal here and now call this place home. Anyway, our log house is about 75% finished. I've got a question about windows. We got this carpenter to cut the log windows out, put in the splines and make the casings. The casings are already screwed in but fortunately not the windows yet because there is a problem.
The casings are wobbly because this guy cut the grooves 3/4" wider than the spline itself making the window wobbly. Before he put in the spline he put some fabric packing material in as they do here...I'm worried about shrinkage in the future. He only secured the casing from the sides with 4" screws...but not the top or bottom plate. Can anyone suggest a way to make the casing stronger. the winters here are as you know really severe so everything must be really tight. I'd appreciate any help or direction on this. thanks for reading...Please help...winters coming!
Dan
Admin's note: Dan's project is here.
Malamute
# Posted: 13 Sep 2011 10:57am - Edited by: Malamute
If you can get the bucks (frames) and splines back out, you could shim them with long wood strips. They need to be able to settle down the splines as the logs settle, but shouldn't be loose. Should be a little free space above them also to allow the walls to settle and not crush the window frames. I use the black foam pipe insulation for those larger gaps above windows and doors, like extra large backer rod, and chink over them with Log Jam. May not be able to find that where you are, but whatever you use, it should be compressible. I've worked on old work (10 yrs old) that they didnt use a compressible enough material (high density foam, and too tightly packed fiberglass insulation) and the windows were being crushed and distorted.
You should be able to attach the bottom of your window frames to the wall, they shouldn't move with settling.
Chinking/caulking both inside and outsides of the window frames should help seal them also, but will need to be rechinked as the walls settle, and may need to be touched up again even later a time or two, mostly at the top, as theres more movement there.
raisadan
# Posted: 13 Sep 2011 11:28am
Malamute...thanks so much!
