Small Cabin Forum / Cabin Construction / Subfloor Moisture
TF1
# Posted: 19 Aug 2024 11:27am
My cabin has been built now for a year now and has been sealed up with vapour barrier for a few months now. Walls are reading 7-9% but the subfloor ranges from 9-16%. Cabin is 2-3 feet above ground with full airflow.
It’s been very humid and rainy all summer. Will a vapour barrier on the surface plus vinyl plank be okay or do should I be looking at installing something in the joist cavity to help reduce? For reference I left a rubber entrance mat at the front door and it started to mould on the underside.
Thanks
# Posted: 19 Aug 2024 01:18pm
All closed in, as in not ventilating?
Can you get a fan going, ime air has to be moving and have a way to vent.
TF1
# Posted: 19 Aug 2024 01:25pm
Thanks I have a full roof vent cap for air above the insulation and I leave the windows slightly open (apart from the gable end windows that are open full time. Full off grid so I only run a dehumidifier and fan when I’m up. I’m not sure what other options are while I’m not there.
# Posted: 19 Aug 2024 01:32pm
Did you ever arrive to a cold cabin and outside was warmer and then you opened the place up?
There are other ways to run a dehumidifier offgrid but it can be pricy. DC direct from solar mini split.
Also some times leaving the place closed up allows for less temp change and less condensation to form. How much floor insulation do you have?
TF1
# Posted: 19 Aug 2024 05:28pm
There is currently no floor insulation. I’ve been trying to decide if I want to put in spray foam or rigid.
I don’t think the numbers are that bad (only the subfloor that has higher than ideal), I just didn’t want to add a vapour barrier the flooring only to add foam or rigid later. Both would trap moisture if vapour laid on top of sub floor.
I don’t have any visual signs, I just happened to check. The humidity (Quebec) has been horrendous this summer so I was also hoping to see what it would be in more normal conditions.
TF1
# Posted: 19 Aug 2024 05:29pm
Sorry - yes it’s typically cooler inside than out before everything gets open. I was under the assumption that little window cracks would be better than fully sealed.
# Posted: 19 Aug 2024 10:24pm
Outside warm air hitting cold interior objects makes condensation. Either way with no insulation your fighting a loosing battle. You need floor insulation to slow heat/cool loss.
I would definitely do ridgid foam right against the bottom of the subfloor.
# Posted: 19 Aug 2024 11:31pm
Quoting: TF1
If spray foam is reasonable in your area, it is probably the best way to go as it will seal most if not all air intrusions as well.
# Posted: 20 Aug 2024 12:13am
I would pay someone to install spray foam rather than do foam sheets myself.
SCSJeff
# Posted: 20 Aug 2024 02:23am
Same setup.. Cabin on piers. No insulation underneath.
I had the same problem once or twice too when conditions were "just right"... Moisture under the floor mat at the door.
My floors aren't finished yet and I didn't worry about it.
However, I do want to be cautious about what flooring I put down in conjunction with what insulation underneath. I don't want an impermeable surface on top (ie: vinyl plank, etc.) with also an impermeable surface underneath. Spray foam, vapor barrier, etc...
According to Building Science, one side or the other should be able to "breath"
TF1
# Posted: 20 Aug 2024 07:02am
What flooring are you considering now ?
# Posted: 20 Aug 2024 10:13am
I'm doing vinyl plank flooring with poly iso foam under the subfloor. With no air gap you leave little room for moisture.
jsahara24
# Posted: 20 Aug 2024 03:45pm
I had our place spray foamed, best decision I've made....
First of all it sucks crawling around underneath the cabin, let alone having to install rigid foam board while crawling around.
TF1
# Posted: 20 Aug 2024 07:14pm
Thanks. I’ll start to price out both iso and spray.
# Posted: 21 Aug 2024 01:50pm
Quoting: jsahara24
Same here! We did under the floor one year and then the perimeter skirting the next.
TF1
# Posted: 22 Aug 2024 02:08pm
What R value did you have sprayed? Early quotes are 20/31.
