Small Cabin Forum / Cabin Construction / Wondering if We Should Start Over
<< . 1 . 2 . 3 .
# Posted: 14 Dec 2023 06:31pm
We are having some wiring chase predrilled during assembly, and that includes a chase milled in the bottom run of logs around the perimeter to be covered with a baseboard.
Also a run on the left side of the door to step in, flip a switch and power up at least one moderate size ceiling fan c/w led light. They run the Romex for that as it is inside the plank ceiling.
Def need some outlets at the corner galley kitchen.
Fortunately that is the corner I want to bring my 'power tap' in from the gen with an RC type receptacle.
Still have 3 of the 7 window placements do settle on for sure and certain, too.
Very Close to a finalized plan on my end then they will do a computer version for my approval. They have a couple in the works right now, may be able to start ours in Feb.
# Posted: 14 Dec 2023 06:38pm
If you might install a direct vent propane heater at some point maybe keep in mind the rules for widow placement, etc. Maybe you already have thought of that.
-izzy
# Posted: 14 Dec 2023 06:44pm
Thanx for that headsup, Izzy
<< . 1 . 2 . 3 .
