spencerin
# Posted: 25 Nov 2022 02:39pm
Reply Quote
The crawlspace of my cabin is enclosed with metal skirting. When it's rather cold outside, the underside of the cabin within 3 feet of the skirting gets a lot of condensation, obviously due to the temperature differential.
I'm considering spray-insulating the skirting (at least 2" thick), and sealing any holes I can find, to prevent this from happening. Any reason why this wouldn't work, or that I shouldn't otherwise do this?
Cedar Fever
# Posted: 25 Nov 2022 03:14pm
Reply Quote
Will you be trapping in moisture under the cabin seeping out of the ground?
travellerw
# Posted: 25 Nov 2022 03:52pm
Reply Quote
Quoting: Cedar Fever Will you be trapping in moisture under the cabin seeping out of the ground?
I would agree. I think it would be much more beneficial to to insulate the underside of the floor!
# Posted: 25 Nov 2022 05:33pm
Reply Quote
We did both. We have a billboard tarp covering the ground. I will say it is very dry under the cabin as we are on a hill. Moisture under the cabin has not been a problem.
Two years ago we spray foamed under the floors, 4". Then last fall we spray foamed the perimeter which is metal with 2". Still no moisture issues. The benefit of the perimeter foam has been warmer under the cabin in the winter.
If your area is moist I would definitely ventilate the crawlspace during the summer.
spencerin
# Posted: 25 Nov 2022 06:18pm
Reply Quote
Well, the goal is to reduce condensation, vs. floor temperature, so I'm not sure insulating the floor will contribute to that. Could be wrong on that, though.....
It's humid under there, yes, but I'll also cover most of the ground with a vapor barrier.
My thinking is that if I can keep the crawlspace and outside temperatures separated as much as possible, that'll reduce condensation.
My cabin, too, is on a hill, but it's just humid under there. I do already have a mechanical ventilation system installed (a small vent in each corner and a duct fan). I'm thinking sealing up the nooks 'n crannies with spray insulation will help with cross ventilation also.
Am I on track here???
# Posted: 26 Nov 2022 10:28am
Reply Quote
Yes. I would put the vapor barrier down first and run it up the wall 8" or so. I believe that is the source of the moisture. Spray foam the walls after so the edge is sealed also. Good luck
